vibration at higher speed
Hey everyone I'm having a bad vibration at 75mph. Tires are all balanced good, u joints are good. If I put the clutch in and put it in neutral the vibration stops and everything is smooth. Doesn't seem to matter which gear. Could this be the result of a bad tailshaft bushing or something worse?
I had a clunk when I would shift into 3rd, sometimes a shutter, and a vibration in 4th (od, I'm a A4 ) on the highway. Checked my u joints they seemed fine, after a few trips to the track it got worse so I yanked the driveshaft out and had it balanced and new joints pressed in anyways. Every issue is gone, I think the driveshaft is something to look into
How much would you want for the aluminum one if you wanted to sell it?
Just a guess but it may be your rear end. Auburn diff.?
I would get the back end up, pull the cover off and check the spider gears and ring and pinion. If all looks good fill it back up and add two bottles of limited slip additive
Could that also be what's causing the vibration?
