Injector upgrade question
Hey guys got a question about what injector to go with. I am planning to make anywhere from 400-420 on a nitrous outlet plate 125-150 shot. The car is full bolt ons etc. I was thinking about a 32-36# injector from racetronix. Any input would be greatly appreciated!
So your saying 400rwhp on the bottle. If so then just run stock injectors. Just make sure you run a wet kit. Wet kit supplies its on fuel. Its alot safer than dry kits. I would just pick up 255 pump, colder plugs and pull timing.
Yes I will be running a wet kit from Nitrous Outlet and I have a racetronix 255 replacement pump and hot wire kit waiting to go in.
What travis said, you don't need bigger injectors for a wet kit. It pulls fuel from the fuel rail. A Mallory 685 box is a good piece to pull timing and it has a window switch.
I am actually pulling timing with the MSD Digital 6 Plus. I am using a NX window switch to set rpms.
