lt1 stripped block
lt1 stripped block
My buddy has a 95 firebird with a stock lt1 full exhaust and msd ingition nothing wild done to the car cylinder 8 the spark plug keeps backing its self out of the head l. Has this happen to anyone else??? Any help??
I have been trying to talk him in to a ls swap i know that would fix everything!!!!
And no an LS swap would not fix his problem, nothing wrong with an LT1 if you know what you're doing. Also what sort of MSD ignition? If it's any sort of iginition box, it's probably doing more harm than good on a bolt on LT1 car, the Opti is already a high voltage ignition and doesn't need help from an MSD box.
I would get a reverse tap and try to see if maybe some one messed the threads up. It would be a lot more work involved doing a LS swap when it can be fixed or upgraded for a small amount.
Village Troll
Does he use anti seize compound on the threads? If it has stock manifolds and IIRC the #8 plug can be a pain to access especially to thread and tighten. If anti seize is not used then you can experience a false sense of the plug being tight when it actually is not. Don't mind SNM. He's a colossal Richard.
