Motor lost power for a splt second
This happened twice today: The RPMs suddenly dropped as if the car were going to stall (once at a light and another while cruising). It happened for a split second and then the car keeps going. No CEL or noises; just the sudden drop.
Any ideas what that could be? I am new to the world of superchargers and wonder if the blower could be causing the surge??
Thanks all
Thanks all
May be way off, but did it act like the engine lost power or quit al togather for a split second. if it acted like you hit the key off and on real quick then check your power connections. Like I said may be way off but It is kinda common In general automotive repair. Loose or corroded connections causing an arc.
