Big time vibration
Old 05-20-2015, 01:34 PM
BirdIsTheWord's Avatar
Default Big time vibration
I have a serious vibration issue with my car. A couple weird bits about the rotating assembly.
*Stock Lt1 balancer pulley
*Eagle Cast Steel Crankshaft NOTE (Requires a Chevy 400 harmonic balancer and the use of a stock type counter weighted flexplate or flywheel..)
http://www.summitracing.com/parts/esp-103523750
*QuickTime Balance plate
http://www.summitracing.com/parts/qti-rm-530
*Spec Steel Flywheel
http://www.lmperformance.com/705488
**Spec Stage 3+ Clutch
I bought the car already built, with a different vibration. I added the QuickTime plate, it fixed it. I had the setup on the road for about a year with a stock clutch before the throwout bearing went, and me being a broke college kid, couldn't/didn't fix it for 4 years. Now, fast forward to 2015, the rings and bearings are all fresh, The clutch is the Spec 3+ I talked about, I start it up, and I have a wicked motor vibration. The only thing I changed in the setup was the clutch, so that leads me to believe that the clutch is out of balance. Just figured I would type out this book to get a second opinion, since all of the other LT1s have gone away from the local scene and my group of friends.
For ***** and giggles, here is my motor balancing sheet.
Piston 660 g
Piston pin 1 g
Piston Rings 56 g (original rings not new)
Pin locks 4 g
Total Rod 556 g
Insert 46 g
Rotary 899 g
Reciprocating 875 g
Bob Weight 1774 g
Old 05-20-2015, 01:57 PM
ahritchie's Avatar
Did you change to an aftermarket flywheel recently with the new clutch? If the engine is vibrating with the trans in neutral then it's probably not the clutch.
Old 05-20-2015, 02:04 PM
Village Troll
SS RRR's Avatar
If the the engine was externally balanced via flywheel then the PP was most likely bolted to the flywheel when it was balanced. Do you still have the old PP?
Old 05-20-2015, 03:21 PM
No, I always had the Steel Spec flywheel in there, resurfaced when I put the new clutch in.
The engine is externally balanced via that QuickTime plate thing. I hate the setup, I wish the previous owner didn't cheap out on a crank, I am to blame too when I set up again.
I do not have the old PP anymore.
Old 05-20-2015, 04:43 PM
Catmaigne's Avatar
All of the clutch parts are neutral from the Spec factory. The steel flywheel can be external balance with the bolt on weight or neutral without it.
Old 05-20-2015, 06:41 PM
bufmatmuslepants's Avatar
Broken eagle cast crank
Old 05-20-2015, 08:03 PM
hrcslam's Avatar
This.
Old 05-21-2015, 07:54 AM
StealthFormula's Avatar
Yo what's up Caleb, been a long time man!
I don't trust Eagle cast cranks, Corey who used to own that dark green Formula had his Eagle cast crank break. I certainly hope that's not the case though.
Old 05-21-2015, 09:56 AM
I have snapped cranks before, the vibration really isn't that extreme.
I don't think it is. I know the crank is a total peice of crap though.
If you would like too, stop by and check it out yourself! Shoot me a PM with your number. Its right over in Pipersville.
Old 05-21-2015, 06:02 PM
Guys I appreciate the responses big time! Still brainstorming..
Old 05-21-2015, 06:20 PM
Village Troll
SS RRR's Avatar
Perhaps a dumb question, but did you take the plate off/install it correctly when doing the clutch?
Old 05-21-2015, 06:42 PM
I am pretty sure that it only goes on one way, so that shouldn't be it. I know for certain it is up in there too.
Old 05-22-2015, 08:07 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Did the car sit for 4 years without running?
Old 05-23-2015, 12:29 AM
guppymech's Avatar
Unfortunately with the current state of available clutches for the LT1 you can't assume any of them are balanced correctly out of the box. You should get the clutch PP checked for balance. What's nice is you can use your Spec steel FW for this as with its bolt on weight removed it should be neutral balanced. It doesn't take much imbalance to get things shaking.
Here's a link to a GM Service Bulletin I found about fine tuning the balance of the clutch/FW assy on the car with the bellhousing inspection cover removed.
https://ls1tech.com/forums/manual-tr...tructions.html
When my engine was vibrating from the clutch/FW imbalance I could only detect it with the trans installed. During troubleshooting with just the FW and clutch installed (no bellhousing or trans) and running the engine everything appeared smooth but after I installed the trans then it vibrated, very frustrating.
Old 05-26-2015, 08:59 AM
Yes, more or less. It sat for 2 years with the bad throwout bearing, with myself occasionally starting it. Then 2 years to tear down and rebuild the motor, trans, and install a new clutch.
Thank you very much. I am about to leave for Ohio for a week, after that I will come back to this and see what I can find. I'll update with progress soon.
Quick Reply: Big time vibration
