Solid roller 383 LT1 dyno **7/19 Update**
Been a couple years since this car was running. The last motor had issues from poor machining, big leak down numbers, and out of round crank journals. Had 40 passes/2000 miles on it before pulling the motor. Decided to go more radical with the motor, and run a Holley EFI setup. Everything is finally coming together..
Early April the motor came off the engine dyno. It made 632 HP at 7100. A 850 carb was used for break in, and the pulls made without tuning just to get a ballpark for my converter.
I have been working every spare minute Ive had getting the car back together, everything plumbed and wired in, and the bugs worked out since April. It finally hit the rollers yesterday for tuning. It made 477 rwhp @ 7000 rpm on a very stingy Mustang dyno through a 4L60e, 5800 8" converter, and S60 rear with 430 gears. AFR was rich at 12:1, more tuning to come..
This pull was to 7500 RPM and it still isnt dropping off.
Next stop is the track
**UPDATE 7-11**
The track has been closed this year due to rain more than it has been open. Ive been there twice, and both times had issues with the tune. I was having sensor issues causing a lean spike at the launch. I got that figured out and all is smooth.. I made a shakedown pass leaving at half throttle and getting on the brakes at the 1000 ft. It went 11.6@110.
Second pass I gave it hell..It spun a bit and the front end bounced to the 100 ft or so, no camera man tonight.. so the suspension tweaks will have to wait for the next time out. I am just happy it finally made a full pass!
**What felt like spinning actually appears to be a early shift into 2nd gear at 10 MPH..
**UPDATE 7-19**
Went back out on Friday night.. first pass off the trailer it went 10.24@132 on a 1.41 60 ft
A couple passes later it went even quicker. This car is really surprising me!
**UPDATE 7-11**
**UPDATE 7-19**
Thanks! Combo is..
383 13.2:1
215cc 23* LE Trickflow
LE Victor EFI
Wilson elbow and 105mm TB
Forged Compstar bottom end
Diamond pistons with a 6cc dome
.43/3mm ring package
Gz Vacuum pump pulling 9"
Comp cams HXL lobes 268/276 .050 and around .720 gross lift with 1.6 shaft mounts
ATI balancer and flex plate
Sunoco 112 leaded
Lenny at Ultimate did the converter.. it's a 8" non lock up.
Thanks! That particular dyno gets rpm from wheel speed, so the graph reads about 500 rpm lower at peak because of the tire growth and big converter. A tach pickup based rpm signal would have shown higher numbers.
That motor was a picky bitch to tune, but Tim did a excellent job. Running open loop for now.
Thanks fellas!
383 13.2:1
LE Victor EFI
Sunoco 112 leaded
Thanks fellas!
The car is pretty light, need to scale it. It is atleast 100 lbs lighter than 2 years ago, maybe more. I am gonna guess 3300 raceweight. 5800 rpm stall, 4l60e, 430 gear; 28" tire.
Nice numbers man... you'll love the 8 inch converter. My car picked up a lot of et going from a 10" 3800 to an 8" 5200.
Very interested in how it pans out for you. ...
Maf or speed density ?
I hear you on tuning. Even though I'm going 24x, I will still be speed density so will need to find a damn good tuner to get it done.
We need to get our cars together once dialed in, seriously.
I think they will be dead nuts even!
Definitely! Maybe the shootout next year..
We made around 15 pulls on Saturday, and the employees at Dollar General did ask what we were doing over there They dont get a lot of open header cars on their dyno, so it is rare that it is so loud.
