Cruise Control Route
Does anyone have a picture of how the cruise control cable attaches to the metal heat shield on the driver's side front frame rail near the hard brake lines? I really need to know how it is attached and what clip I need to look for. Does it connect to the bolt that holds the metal heat shield against the frame rail?
Mine has a clip that bolts to one of the heat shield bolts, goes in front of the shield, up the side to the left side of the brake master cylinder(referenced as to sitting in drivers seat), then to the left of the brake booster, clips to the side of brake booster via another clip, then up above the booster and to the throttle body.
However, I'm not sure if that is how it was stock...I'll go through some old pictures before I ever touched it to see if I can see how it was....
Here we go, this is how it was before I ever touched it. Routed in front of the shield. Pinning it between the shield and car may allow the shield to cut into it over time.
