Tire Size Suggestions
Old 05-31-2015, 10:03 PM
Zacks94Z's Avatar
Default Tire Size Suggestions
Hey guys, the new; cc503/nitrous outlet plate build ball is rolling and I am curious what you guys think I should run tire size wise. I am thinking the car should trap between 115-120 area with cc503 and supportive valve train/full bolt ons/ 3.73 gears/ 125-150 shot/ SS3600. What do you guys think?
Old 05-31-2015, 10:13 PM
Prototype007's Avatar
What are you going to do suspension wise? Are you going to run stock size wheels or a big & littles combo?
With some effort and math, you can probably hook on a decent track with a 26x8.5x15 slick since you'll be using an auto. Or if you want to run oem suspension, want the big tire look, and hook up decent you can use a 275/60/15 drag radial and not beat in the factory wheel tubs.
A lot more windows of opportunity and forgiveness when running a stalled auto.
Old 05-31-2015, 10:20 PM
Zacks94Z's Avatar
I have stock suspension with just umi LCARB's.
Old 05-31-2015, 10:21 PM
hrcslam's Avatar
What are you planning for shift point? On 26" tires, at 6,700rpms, with 3.73's in third you'll be at 139mph with no converter slip. With 4.10's you'll be at 127.
Old 05-31-2015, 10:27 PM
Zacks94Z's Avatar
I already have the 3.73 gears, I was afraid 4.10s would be too much because I do enjoy to drive the car small amounts to car shows out of town. Also traction was a big concern of mine so I compromised with the 3.73s.
Old 06-01-2015, 07:59 PM
myltwon's Avatar
Don't run a 28" tire unless you roll the fender lip.
Quick Reply: Tire Size Suggestions
