fresh 385 supercharged break in?
So we just got my 385 running today. It has a vortech v1 t trim with callies dragonslayer crank, coated mahles to reduce fricition, clevite bearings, trick flow heads and a custom blower cam.
The only brand new parts are the pistons and bearings. Cranks head etc are all used. My questions is, the car is untuned. To break it in should i do the normal stuff or do i need to take it to a shop to let them break it in and tune it at the same time?
Its an a4 car also. I want to know the best and safest way to break it in. Will going into boost on a practically fresh motor **** **** up? Do we need to work out how rich/lean it is by letting them tune it first or whats the best route?
When questions like this are asked there is a high probability that the person has already made up their mind and just fishing for support. There is an equal probability that those people will start a new thread about how it all went wrong. It is your hard earned money so reflect on this really hard and please take the tuning advice.
Could i haul it to a dyno shop and get them to tune it or do i need to get a mail order first?
The mail order tune idea was just for break in purposes like idling, getting the motor up to operating temperature and some very light driving. If you can haul it to a shop with a dyno and arrange a tuner to meet you there then that would be awesome but consider their time (tuner and dyno operator) could get a little expensive waiting for you to change oil and check plugs after a heat cycle or two.
I had a good experience with pcm4less about 8 or 9 years ago mostly because Bryan tuned my car in person on a dyno for a group event. A friend of mine had a good experience with them for simple mail order calibrations. There are a lot of people here who agree and just as many with different opinions.
Man-Crush Warning
I tossed a friends SC tune on my car for start up and idle check, verified stuff works, and then hauled it to a dyno shop for their tune. They gave me a no boost break in tune and I drove it for a few hundred miles with varying RPM/vac levels. Then, finished up tune on dyno for positive pressure and WOT stuff.
Would it be ok to get the car to temperature and make sure everything is working with the hotcam flash? No driving just idling etc then once i know its all working haul it to the dyno? Or should i just take it to them? Im expecting about 500 to tune it.
Mail order tune and a wideband to keep an eye on things would be a good idea. If things look OK, you can break it in but keep out of boost for the most part. Make sure she is not pissing fluids or having any other issues. Get it on the dyno and have it tuned properly. You will want to avoid long idling periods.
My mail order was too far off for all of this so it was broken in on the dyno.
