Those who wired their 2 step off clutch pedal need help
I have a 95 z28 6 speed... i recently hooked up my 6al2 msd box and there is a single blue wire for a 2 step hook up.. I wanted to hook it up to my clutch pedal so i can leave off the line building boost.. i dont want it on a switch or button... i know its possible to hook this up on the car because i had a shop hook it up to my old 94 z28 6speed... For those who know how to wire this up or did it before could u post pictures of anything to help me wire this up in my 95... i hate to wire it up wrong.. im just worried that every time i hit the clutch in to shift it will drop to my desired 2 step setting. --- any info or help will be great
Here's diagram of how mine is wired.
I wanted to clutch switch to function normally and the 2-step to only work in first gear.
I have it on one switch to activate the 2-step, a switch mounted on the shifter so it's only active in first gear and a hidden DPST switch that switches the clutch switch to either function like normal or when flipped it works with the 2-step. A bonus of wiring it like this is when the hidden switch is flipped for the 2-step to be active it acts like a theft deterrent switch.
