Steam tube
Steam tube
I was wondering where others have run there steam tube that comes from the back of the heads to. I know some are running a radiator with an extra nipple to run it to unfortunately I'm not one who has that luxury, I know some have had it added to an aftermarket aluminum rad but I don't have that option either as mine is copper. Is there an after market overflow/recovery tank that has an extra nipple possibly for such?
Need more information on your setup. What car and are you running heater hoses? You can't really run it into a recovery tank. It needs to run into something flowing back into the radiator.
It's been ages (and mine is an odd ball 93) but I'm pretty sure on mine it doesn't run direct to anything on the rad, but joins one of the radiator hoses at a plastic Y fitting (normally going through the TB first). Two sides of the Y are the fat rad hose diameter and the third is just a tiny barb. I can't imagine that factory Y piece being too much money and you can easily just cut a hose and install it with what you have. Apparently some have also tapped a 90* barb into their waterpump, but that seems way overkill to me unless its a show car that you want as much stuff hidden as possible.
I would keep the system working as close to factory as possible. For the head side, I know I made a super cheap setup ages ago using heater hose from Autozone that was like a buck somethin per foot, and some fittings from Lowes and a small amount of teflon paste.
Ugly as hell, but its hidden in the back and works fine so who cares???
I used a heater hose t that had a 1/4" nipple and ran it to the return hose from the heater core. this is modled after an F body as some of the factory cars has it returning to the heater hose.
got it from Oreilly. I'll see if I can find the part #http://www.oreillyauto.com/site/c/de...0886&ppt=C0108 this is the one for 5/8 and here is one for 3/4 http://www.oreillyauto.com/site/c/de...0886&ppt=C0108
