Speedo calibration help...please!
Can anyone help me with my Speedo, seems to be 9-10% over what it is actual via speedometer app on my phone or GPS. 30 is 33, 40 is 44, 50 is 55-56 60 is 67ish. Attatched is my calibration screen from my laptop. Burned two pcms in 2 years due to fluke situations, really like to get it right once, don't want to guess n test if I can help it. Thanks for the help!
Forgot to mention, 4.10 gears in the back (4th gen 10 bolt), lt1/t56 from a 94 i believe, and 285/40-18 rear tires on vette y2ks, not that half those details matter that I know of but trying to include all that I can.
Bump,
Finally found some threads talking about this and said to use rev/mile as it's most accurate, can anyone tell me what all the parameters should show to confirm it's right first time please. Again, t56, 4.10, 285/40/18 tires
That's what I thought was off after I saw it and looked up measurement with tire size. If anyone can give me a break down of all the specs from tunerpro or other software on the right of the first pic so I can be sure to get it perfect that be great, thanks!
when I changed my gears I used tunerpro to change it and i just divided all 3 numbers by the stock gear ratio then multiplied them by the new gear ratio. I feel that tire changes would be the same.
