Ok im lost here...
Old 06-29-2015, 11:08 PM
Boosted Firehawk's Avatar
Default Ok im lost here...
Crazy stupid setup but cant figure this out right now for some reason
3.48 stroke crank
what rods needed?
4.040 piston for nitrous setup
What will work for this setup?
Thanks
Old 06-30-2015, 05:44 AM
bufmatmuslepants's Avatar
Depends on the compression distance, for a 6" rod you'd need 1.260", for 5.7 you'd need 1.56, 6.125" rod you'd need 1.435, etc.
Old 06-30-2015, 07:51 AM
5.7 correct????
1.563 comp. Distance
flat top
Old 06-30-2015, 03:00 PM
Catmaigne's Avatar
Stock deck height is 9.025
9.025 - (stroke/2) - rod length - comp height = 0
I'd run 6" or longer rods to keep piston weight down.
Quick Reply: Ok im lost here...
