Malf 36: Opti Fail... AGAIN!!!
Looking for some guidance here fellas... I'm currently running a "Cardone" brand Opti, installed last summer, this one has roughly 1000 miles on it.
Driving Sunday, car is running great (first time out this summer) at a red light after driving for about 45 minutes, and the engine dies. Try to restart, but it won't fire. Tow it home, scan, Malf 36.
I tried starting it again yesterday, fired right up and I had it idling in the garage for about 20 minutes, purred like a kitten, smooth idle...
Here's where I'm a little confused... When I've had Opti's die out in the past (and I've had a few) they usually die out with a bang! Misfire, kicking, bucking, etc... They either work, or they don't (in my experience). Odd that this one died out (after running beautifully), and now it's working again.
Has anyone else been in this boat? Just looking for some insight before I go cough up more $$$ for another Opti.
Oh, one thing to add which may or may not be related... About 20 minutes into the 45 minute drive Sunday, my ABS light came on. Brakes worked fine, and I'm not sure if this is just a coincidence or not, but thought I'd make mention.
Thanks to all in advance!
As for the ABS, probably random and unrelated...mine comes one every now and then for no good reason and goes away by itself
have you tried a different icm? mine would do similar things like yours as far as shutting down etc even an occasional backfire.. put in a new icm and it ran great for years... now my opti is replaced but it had 157k on the original and was worn out
Code 36 is opti hi res signal problems. Could be the harness going to the opti, but most likely is the poor soldering for the hi res signal board in that cheap opti.
Use the Buick Know how Video for the LT1 Opti to check your signals.
Always best to diagnose before buying parts, but I think you need to get an Delphi or AC Delco opti unit and call it a day.
You'll need to get it scanned for ABS codes....I think this can do it for your 94.
http://www.camaroz28.com/forums/comp...95-lt1-874306/
Thanks for the input fellas!
Mackdaddy, I'm still running the stock ICM, and with the research I've done, it almost seems like the ICM could be the culprit here... Given the fact that the motor just died, and is now running again. No sputtering/kicking/bucking/rough idle, etc. symptoms like I've experienced with a bad Opti...
too bad you didn't live somewhere close to me... my old opti was worn out and had gotten oil in it... just a little bit, but the electronics were still working fine and I have a opti harness with maybe 300 miles on it... would just let you have it
