NA LT1 9.81 @ 138.2 **Updated 11-8-15
Old 07-25-2015, 01:32 AM
PA94Z's Avatar
Default NA LT1 9.81 @ 138.2 **Updated 11-8-15
I broke into the single digits last pass of the night. Very very happy with how quickly this car is getting dialed in! I couldnt hook the first couple passes, made a couple suspension tweaks and dropped the tire PSI and it started hooking.
Here is the pass before the 9.97 pass..
And the slip..
Motor is a 383 13.2:1, 23* LE Trickflows, LE ported Victor EFI, custom solid roller, GZ vac pump. 4L60e and a Ultimate Converter Concepts 5800 stall -that needs loosened up a bit.
Ive got around 12 passes on the new build and have already hit my end of the year goal. Now the question is how deep can I go?
** 9-6-15**
Got some new personal bests tonight.. No changes to the tune just getting the car sorted out. It's leaving really nice now..
Should have a video up of the 9.82 pass later today.
DA was around 1600 ft
**11-8-15**
Last passes of the year.. no new best ET The band in my 4l60e is slipping when trying to engage. I am commanding 1-2 1500 RPM before I need it to. At the top of 1st gear, the computer has not seen RPM drop for the 1-2 shift so it commands the shift to 3rd - it engages 2nd briefly and bumps 3rd.
DA was 500 - 600 ft..
Old 07-25-2015, 02:23 AM
hrcslam's Avatar
Default Na lt1 9.97 @ 135
Very nice!
Old 07-25-2015, 03:06 AM
joelster's Avatar
That is flying! You just bumped me down a spot. 135.01mph is good for another tenth or two easy.
Old 07-25-2015, 04:26 AM
waltsfastz's Avatar
That is some sweet times
Old 07-25-2015, 06:41 AM
Blackbirdws6's Avatar
Hot damn that's impressive. Congrats on hitting your goal so early.
Old 07-25-2015, 06:48 AM
Puck's Avatar
Grats!!! Already in the 9s :o
Old 07-25-2015, 08:14 AM
PA94Z's Avatar
THANKS fellas!!!
Wish I had video of it.. My uncle was packed up ready to go watching from the pits with a dead phone
Old 07-25-2015, 12:38 PM
matt94z's Avatar
That thing is a monster
Old 07-25-2015, 02:46 PM
NewOrleansLT1's Avatar
Nice ride you got there..
Old 07-25-2015, 04:27 PM
TravisMcGill2000's Avatar
Great job. That thing is rolling.
Old 07-25-2015, 07:48 PM
3 pedal SS's Avatar
Nice running and sounding LT1. Whats the weight of the car?
Old 07-25-2015, 07:58 PM
PA94Z's Avatar
Thanks guys! The car continues to impress me every time I take it out. Small changes are paying off big,
The car weighs 3200 to 3300 with me in it. I will scale it at some point, but that is my best guess for now. Still have all glass in it, stock kmember, stock front suspension aside from coil overs. I took a lot of weight out, but added some in also.
Old 07-25-2015, 09:25 PM
badfbodyz's Avatar
What a beast
Old 07-25-2015, 10:38 PM
What's the rwhp if you don't mind me asking..
Old 07-25-2015, 11:05 PM
BOLO's Avatar
Congratulations! Very nice. Lt1 in the 9s on muscle, impressive to say the least.
I want to say you have a very nice top end combo by Lloyd Elliott thats definitely putting down some serious power.
Old 07-26-2015, 07:44 AM
bowtienut's Avatar
Congrats!
You're doing a lot of things right to do that. Great job
Old 07-26-2015, 07:49 AM
BIGsmokey10's Avatar
All lies. Tell everyone it has a 200 shot on it! I'd like to see some passes in some cool mine shaft air. That thing is going to move.
Send me the new data logs so I can check them out .
Congrats !
Old 07-26-2015, 11:15 AM
PA94Z's Avatar
Thanks fellas!
Bolo - Lloyd does some really nice work! He is under rated for sure. I have a really great machinist too and that helps a lot! The bores are round and everything is right on. Specced a camshaft for the motor that pulls right up to 7500 where I shift.
NewOrleans... the car made 477 rwhp on a rich base tune. It was a low reading Mustang dyno with RPM graphed from wheel speed. I will probably get it back on the dyno to see where Im at end of the season.
Kyle - shhhhhh
Old 07-26-2015, 12:25 PM
ChazWhiteZ28-'s Avatar
do you run pump gas with that CR?
Old 07-26-2015, 12:46 PM
SS MPSTR's Avatar
Nice short time too. Congrats.
Quick Reply: NA LT1 9.81 @ 138.2 **Updated 11-8-15
