parts question
parts question
Phone acting up. So I will cut to the point 355ci forged H beam rods and pistons 10:5.1 compression all ARP, full bolt ons. leaning towards 1.6 harland Sharp rr, has anyone ran them? Has anyone run the Lunati Voodoo line? check them out and let me know if you have ran them or if you think these are good choices. Leaning towards the summit kit, I called lunati ironically they can't beat summit on the price.
https://www.lunatipower.com/Product....d=4480&gid=289
http://m.summitracing.com/parts/lun-20080721k
Harland sharp rockers and solid. Comp pro magnums are what I run but harlands are good. Lunati makes good products but that price seems off. With those cams you can run a quality oem style lifter. I run Morels. Had comps too, didnt see any benefit for the extra cost. You can get a custom grind and a set of morels for about the same price as that lunati kit. You can get an off the shelf cam and morels for under 400 I bet. Hell the GM847 can be had for $250 and Morels were about $100. Good luck.
http://www.summitracing.com/parts/cca-1605-16/overview/
Also, you need to up that compression, that's basically stock. 11.5:1 would be better.
