Built 383 lt4 runs ok but misfires abnormally.
I have a 383ci 96 corvette lt4 that i picked up from a guy recently. It was misfiring a bit and i have now replaced the entire ignition system to no avail.
(New opti (4 of them) some worked 1 didnt new wires (accel superstock)new plugs (autolite) new icm (bwd)new coil(bwd) new 02 sensors (denso) new maf (cordone i think) new map (bwd) recent valve adjustment new opti harness. I just dont get it. Yes i did use the cheaper optisparks. $149 new from advance and 1 from autozone ($153) car has good compression and good leakdown. Im experiencing misfires at less than 10% throttle or anything over about 4500rpm and its intermittent. Under %10 is always there but over is hit or miss. I dont know where else to look. No wires are touching the headers and nothing is arcing. Any help would be appreciated guys.
Don't cheap out on one of the most important and critical things that effects how a LT1 runs. That damn thing can leave you stranded. Dont forget loctite and sealant for the housing.
Do the Accel wires have a carbon impregnated fiberglass conductor or are they the spiral wound conductor type? The carbon fiberglass conductor type is very susceptible to failures from bending or pulling on the wires, basically junk. Hopefully you have the spiral wound variety.
They are the super stock build it yourself wires. Unsure of which i have. I know they have similar to a spun wire in the center.
As for the optis i figure one of 4 would have made some kind of difference? 3 ran about the same ya know what problems im having now 1 barely ran at all.
http://www.ebay.com/itm/BRAND-NEW-ACDELCO-OEM-LT1-OPTISPARK-DISTRIBUTOR-PART-1104032-IMPALA-SS-1994-1996/121605450320?_trksid=p2046732.c100040.m2060&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140107095009%26meid%3Db47f00a8eb094e9db2bc9e86e3f7ea67%26pid%3D100040%26rk%3D4%26rkt%3D4%26sd%3D230691061057
Dont be surprised if you still have the problem with an OE opti, though it is still a good idea to get one. Even if you did get four bad ones from the parts store chances are low that they would yield the same problems you described for each one. If it had never ran good and it is a modded 383 i would check with whoever tuned it.
The question about did it ever run right is a VERY good one that could guide a lot more questions if answered.
Cheap wires built DIY style sounds BAD too.
joelster's question is good as well.
I wouldn't fixate on parts swapping, you have put a bunch of lower quality stuff on it but even a crappy chinese opti 1 in 4 is likely to have functioned decently.
What plugs?
Few build details?
What plugs?
Few build details?
Actually yes it does run better in open loop. And i dont know if it ever did or didnt run any better i bought it this way thinking an opti would fix it.
Build details are as follows
Eagle 4340 forged crank
Eagle esp 4340 h beams
Mahle forged pistons
Clevite h series bearings
Arp hardware
AFR #1039 cylinder heads(competition pack)
Ported matched lt4 intake
Bosch 44 lb hr injectors
Bbk power plus throttle body
17/8 longtubes
Comp 292 xfi-hr camshaft
Comp ultra gold roller rockers
Trick flow pushrods
Afr guide plates
Arp head bolts
Cometic head gaskets
New water pump
Arp hardware
17/8 longtubes
Trick flow pushrods
Afr guide plates
Arp head bolts
New water pump
so it is a magazine build that never ran right, you have a serious uphill battle and need a knowledgeable local enthusiast to try to sort out.
If the springs are the standard AFR, they are not up to the task of that cam and you will find high rpm float to be a problem
Wtf? Any build is more or less going to look like that. Magazine build....because it doesn't have a custom AI cam and AFR heads....when was the last time a magazine did an LT1 build anyways?
