Who still makes a turbo kit for the lt1
Old 08-17-2015, 09:18 AM
ss27gogeta's Avatar
Default Who still makes a turbo kit for the lt1
I called forced inductions today to ask them about the turbo kit they make for the lt1. and they said it's no longer in production fabing a kit is not an option for me. if i cant find somebody that still makes a good kit. I'll have to go pro charger so I don't waste a fully forged engine that I had built for boost.
Old 08-17-2015, 09:32 AM
hrcslam's Avatar
STS should all make them.
Old 08-17-2015, 09:47 AM
ss27gogeta's Avatar
I'm wanting a front mount more than a rear mount and I've read that the sts needs additional fabrication to get it to work good
Old 08-17-2015, 10:16 AM
J LT1 TA's Avatar
Type in lt1 boost in Google. It should come up. I don't believe he is a sponser on this forum
Man-Crush Warning
Shownomercy's Avatar
Contact Tick Performance, or you could try Jon @ LT1boost.
Old 08-17-2015, 11:27 AM
ss27gogeta's Avatar
called tick performance had no luck there i sent Jon an email but the luck ive had so far i don't expect any thing from there either. so it looks like a d1sc pro charger is in my future
Old 08-17-2015, 11:52 AM
Man-Crush Warning
https://ls1tech.com/forums/forced-in...wtq-19psi.html
Tell them you want that hotside?
Old 08-18-2015, 08:28 AM
sleeperZ96BT's Avatar
I have a custom built, brand new front mount SS turbo kit (non-intercooled) built by Jon (the guy mentioned here; lt1boost I think) in partnership with Jason Short, who is a well respected member; both are engineers by trade.
The car was literally built on Jason's 97 Camaro SS and went back and forth (the frame w/motor) between Jon and Jason to make sure it fit perfect. If you have a 1997 Camaro SS I would virtually guarantee it would fit perfect, and quite frankly would think on any LT1 Fbody I could say damn near close to the same. It loses AC but has almost stock ground clearance, which as many can attest is rare. It is brand new and complete with a refreshed precision turbo, includes high end hardware and gaskets, etc. It's the proverbial cats meow, as they say
I was planning on doing a turbo build but I am getting to that stage where reality is setting in with my almost two year old and a new house. It will probably be years until I use it. I would consider parting with it, for the right price, but please know there was literally no expense spared in designing and spec'ing this kit. If you are interested feel free to shoot me a PM. I believe all it needs is your choice of BOV and Wastegate, otherwise it is complete. I also have a dual intank fuel pump to support the power I planned to make.
Old 08-18-2015, 12:14 PM
ss27gogeta's Avatar
Thanks for the offer sleeper but I'm not 100% ready to get a kit yet I was mainly looking to see if anybody still made one as I feared that I was going to have a problem getting one and to help me know what cam I'm going to go with as a turbo reqiers a special cam and if I could not find a kit that somebody makes still I was going to get one with a little more lsa and get a procharger if you think you might have it around next spring I might be interested in it as that's when I plan to buy my forced induction setup building the engine for boost has cost me a descent amount of $ I have to take a few months and recover lol.
Old 08-21-2015, 11:13 AM
myltwon's Avatar
Just remember if you plan on getting a new procharger, a f1a isn't much more than a d1sc. Like a couple hundred iirc
Old 08-21-2015, 09:13 PM
ss27gogeta's Avatar
I thought some modifications had to be made to get an f1a to fit
Old 08-21-2015, 09:23 PM
Blackbirdws6's Avatar
The block will need to be clearanced a little bit.
Old 08-21-2015, 09:47 PM
ss27gogeta's Avatar
Is that something a machine shop has to do or can I use a grinder and remove what's necicary with out damage and as for kits I have not seen the f1a as an option only the p1sc and d1sc
Old 08-22-2015, 12:15 PM
myltwon's Avatar
You have to grind a little bit off the corner of the block IIRC. Talk to a vendor there is an upgrade available if buying a new kit. Makes little sense to me if buying a new kit not to go to a F1A for only a few hundred more unless you plan on racing in a class that limits blower size. The F1A will have a higher HP ceiling and be less likely to have blet slip issues than a smaller blower.
Remember if you opt for the F1A the first time it's like $500ish to go for the bigger head unit. Buy the D1SC and want to upgrade down the road, expect to pay around $3500 for the F1A head unit alone.
Old 08-22-2015, 01:02 PM
I did this at home just taking my time with a grinding stone. No need for a pro unless you are entirely uncomfortable using a Dremel lol.
Why would a bigger blower have less of a chance of belt slip? F1A takes more to turn which will increase the chance of slip. Thankfully us LT guys get to utilise a 12 rib system.
Old 08-22-2015, 06:27 PM
myltwon's Avatar
I was under the impression that the larger head unit will not require as small of a pulley to make equal boost to a smaller head unit which equals more belt wrap
Old 08-22-2015, 07:09 PM
ss27gogeta's Avatar
blackbirws6 how many psi were you running to get the hp in your signature. and was that on 93 octane how much boost could I run on an f1a before needing e85 or meth.
Old 08-22-2015, 09:23 PM
17lbs on 93 with meth after 15psi. You don't need meth or e85 unless you want more timing.
Quick Reply: Who still makes a turbo kit for the lt1
