Oil Cooler Delete Bolts
Hello Community,
I am tackling the oil cooler delete next weekend, and I am looking to order some bolts to replace the stock ones. Anyone know the size/thread needed? Or does some site sell a kit? I haven't been able to find anything while searching.
That's MISTER MODERATOR
The bolt size is 5/16 x 18 x 1.25 inch. It's a special bolt with a short head to clear the filter.
https://sdparts.com/details/gm-facto...-parts/3951644
It's used with this filter adapter:
This GM Oil Filter adapter fits all Chevy small blocks from 1968-99 except for LT1 and LS1 and all big blocks from 1968-89.
I guess that description is assuming you are not deleting your oil cooler on an LT1, thus why it won't fit. Is that right?
Ahh, I think I misunderstood.
I ordered the adapter and it looks just like the one I already have.
I guess to do the bypass you can use the stock adapter, you just need the bolts.
The bolts should be all you need. When I removed the oil cooler on my '94, I had also purchased the adapter. It wasn't necessary as the oil cooler was already utilizing the adapter. Things may differ by model year. I believe the cooler was redesigned in '95.
