97 camaro instrument panel plug
Old 09-07-2015, 02:13 PM
B_Mack15's Avatar
Default 97 camaro instrument panel plug
i'm in the process of putting an 98-02 dash in a 94 camaro and I have picked up a 97 camaro instrument panel. Where would be the best place t pick up the connector that goes in the back of it. I have read that 94-97 connectors will also work
Old 09-09-2015, 11:03 AM
madhatter's Avatar
I picked mine up from the dealer for around $5 if I remember correctly. The part number is floating around out there in the dash swap threads.
Old 09-11-2015, 08:58 AM
B_Mack15's Avatar
I'll keep looking on this forum then... I've seen a few dash swap threads but haven't seen the part number listed
Old 09-11-2015, 02:06 PM
NewOrleansLT1's Avatar
Try and find a 94-97 Trans Am and cut the pig tail off, be sure to cut as much wire as possible so you can have something to splice on to.. Then take it home and cut your pig tail off and splice in the new one by color matching the wires.. Start your car up and enjoy your new cluster..
Old 09-11-2015, 02:48 PM
B_Mack15's Avatar
i have not been able to find any trans ams being parted out near me. i don't mind the repinning just have to locate that part number
Old 09-11-2015, 04:12 PM
I'm not 100% sure if you can re pin it.. I think the metal clips are bigger than the newer style and won't fit..
Old 09-11-2015, 04:29 PM
B_Mack15's Avatar
i meant repinning a new one. i just can't find the part number
Old 09-12-2015, 01:00 AM
I don't think you can re pin it at all.. You gotta splice it or solder it in.. But let me know what happens when you get to that stage.. It's been awhile lol
Old 09-12-2015, 06:20 AM
madhatter's Avatar
I simply repinned mine. No reason whatsoever to cut and solder.
Old 09-14-2015, 08:46 PM
96Formula6spd's Avatar
We tried to repin but it did not work. My brother used a 95 Firebird V6 pigtail if I remember. Any 94-02 Firebird or any 97-02 Camaro. We used one from the junkyard with the cut and solder method.
Old 09-17-2015, 04:41 PM
B_Mack15's Avatar
Almost done and I have had no issue repinning the new plug...
Quick Reply: 97 camaro instrument panel plug
