Moroso CAI: Discontinued for 1994-97 LT1s?
Just recently looking around for cold air intakes, and I saw that the Moroso CAI is only available for V6 Camaros or lt1 Camaros from 1993.
Any reason I couldn't make a new one work on my 1995 Z? Just looks like the tube is a bit longer since 1993 doesnt have a MAF. I hear Moroso is one of the better (compared to K&N) intakes. Definitely feels like the car needs to breathe more with GMMG now.
I've heard so many opinions that it isn't even funny. I've heard that K&N is advertised better than it actually is, and I've heard that there's nothing wrong with it. I've heard the slp one is awful, yet I've heard the slp is one of the best. I've heard that Moroso/Callaway is the best, and now I'm hearing that it isn't!
Moroso is an awesome CAI. I don't justify paying the money for some of the more fancy ones like SLP or whatnot. I found my Moroso at the junkyard on a wrecked T/A. 15$ and it was mine, Really though.... Yeah cold air intake = more power but one IMHO really isn't better than the other. K&N would be fine if you have just bolt ons. I know some May produce more power numbers then the other... But honestly on a street car the difference between 11hp and 15 is unnoticeable.
If you can't find a Moroso check out this Trick Flow that looks like a re-branded K&N for $40 less.
http://m.summitracing.com/parts/tfs-...obileSwitchYes
I have a Lingenfelter and like it but they don't make it anymore so you'll have to find it used....probably not worth the effort with the Trick Flow at $180.
No problem man. Try some junkyards and if no luck, give eBay a look. And honestly I wouldn't know but I don't think the extra length would even matter, the Moroso goes down in a hole in the body of the car in between all the Splash panels on the front end of the car, on the drivers side of my car I actually cut a square of it out to have cold air forced into near/around the area of the filter for more outside air. But like I said it's really looking at hyper scientific things between different cold air intakes. Same for mufflers, I've had magnaflow, hooker... SLP LM2 and my car hen it was bolt on, and now being crammed and built, none of those catbacks made the car feel any different because like I said. We're talking the difference between 1-3 HP here. If all else fails and you can't find a moroso, a lid conversion seems to flow the best and look coolest
https://ls1tech.com/forums/lt1-lt4-m...rtube-cai.html
There probably isn't much power difference between them as they all pinch down between the ABS modual and radiator.
I would suggest you look at the installation instructions for the ones you're interested in to note the details of each. Summit or Jegs usually have a link to a PDF. Much better than just looking at pics of them.
When I was shopping for a cai between the ones in this thread I felt the Lingenfelter was designed the best. I like that the tube has a ear on it that connects it to the radiator upper support with a push pin like the stock air cleaner. The S&B washable cone filter measures 9" tall by 6" dia tapering to 5" dia and connects directly to the tube. I made a thread when I noticed Lingenfelter appeared to be discontinuing them.
So does anyone actually know if the Moroso is going to work on my 1995? I don't want to buy one and then have it not fit. As far as I can see the only difference is that the pipe is a bit longer since a 93 doesn't have a MAF.
I'm pretty sure it would be fine. The length difference is maybe 1". But I can't ensure that it will fit. I just don't see why it wouldn't.
Yeah, that was my other question. Does a CAI really make that much of a difference? Is the stock intake and paper filter the weakest link in an lt1 intake system?
Ok, thanks for the input!
Lingenfelter is discontinued unfortunately. From what I see the only choices are K&N, Moroso, SLP, or homemade. Not doing a lid, but I might try a ram air setup someday.
If someone tells you that the difference between 15hp on a street car is unnoticeable, laugh at them and turn away.
My stock air box was holding back 20whp when I was on the dyno. Last couple pulls,Pulled out the stock air box. 20+rwhp!
Stock air box is most definitely a point of massive restriction.
