Sump fueling question
Old 10-13-2015, 09:40 AM
SwampWS6's Avatar
Default Sump fueling question
Whats up?
So im going with a sump fuel setup over the winter, mainly with the ease of being able to grow in size and making it a easy swap to go to a larger pump. But anyways, Im wanting to know has this been done or can it be done.......
Im wanting to keep my intank pump for the sole purpose of a fuel level reader. I know it can be rather difficult to tell how much fuel remains with a sump setup. I am horrible at wiring but I'd rather like to know is this even possible to do. So the question is "Can I keep my in-tank pump as a fuel level reader?"
Thanks for any info!
Old 10-13-2015, 10:24 AM
sweetbmxrider's Avatar
Don't touch it and it will continue to work? The purple wire feeds the gauge. Leave it as is and sump the tank. You will decimate all!
Old 10-13-2015, 10:28 AM
Man-Crush Warning
Shownomercy's Avatar
Yup, leave it all alone, hell ,leave the OEM pump in there if you want. Cap the lines and leave a vent line to a breather.
I ran a line from PCM to a large solenoid/relay for fuel pump in trunk. 10awg and less than a few feet of it. At some point I should add in a fuse to the circuit.
Old 10-13-2015, 02:29 PM
SwampWS6's Avatar
Cool. So just leave it as is? Simpler than I thought. I just didnt want the OE pump to continue to try and pump while the sump was doing so.
I tend to over think things. Almost seem to simple to be true....
Old 10-14-2015, 10:23 AM
Unplug the pump and it won't try to do anything.
Quick Reply: Sump fueling question
