52 mm throttle body
Put the stock TB back on until you get a tune.
larger TB's have their place on larger C.I., H/C motors with the proper "supporting" mods
while the 52 mm won't hurt performance on a basic stock motor........ as you found out your transmission was not shifting properly. Your tranny is saying stop what the F you are doing until you do what is needed to install one.....assuming you even need one
Capricemgr also brings up another good point in that many aftermarket TB's require modifications to get them to idle right. No big deal if you know wtf you are doing, have scan software to read IAC counts the adjustments can be made. A stock TB bored to 52 will be way easier to deal with but you still need PCM adjustments for auto cars
Unless you have H/C, headers, larger injectors you really don't need a larger TB. If so fine but we don't know what other mods you have
I have ran across a few articles were people have ran actual tests on switching to 52mm throttle bodies. They have all netted 6-7 hp and tq.
http://www.superchevy.com/how-to/eng...-motor-part-2/
I have a stock TB bored to 52 mm on my Z28 with auto transmission and never had any issues with it. The car was never tuned and the transmission shifts the same as before I installed it. I always heard that the 58 mm throttle would mess with shifting on auto cars if not tuned.
The 52mm TB on your car will effect the automatic transmission, whether you feel it or not. There's no way it doesn't. The way the computer selects its gears, shift points, shift speed, and line pressures are directly effected by the TPS and MAP sensors, the relationship between those two are directly effected by a change in TB bore.
I've seen it too many times where TB mods are done on an automatic car and the trans fails prematurely due to clutch wear. You don't always feel it, but it's happening.
