Issue in third gear WOT
Not sure if it's engine or trans related.
Not sure if I should have put this in trans section or LT1 section, because I don't have a clue as to what it is.
I logged a run at the track last night. Car ran slower than I expected, could be several things that changed. One of the most concerning things to me at the moment is what's going on in third gear.
The car feels like it's pulling strong, but looking at the log, something is going on. The rpms climb and drop, and the knock count just goes crazy, incrementing by the thousands. This doesn't happen in 1st or 2nd, just third. I Do get a small amount of knock count at gear shift 1-2.
anyone have an idea of what's going on?
here's a pic of the rpm in third vs 1 and 2:
I'd really like to get into the 12s, and if I can get this figured out I'm pretty sure I'll be there.
I think you've already answered your own question. It's detonating in 3rd gear. It's on the ragged edge for timing; by the time you're into 3rd, the loading is at its max and you've put enough heat into the chambers by that part of the run to make it more likely to knock than it does in 1st and 2nd gears. Either run better fuel or tune it for what you're running.
Shell 93 octane has never pinged/knocked/detonated on me. I swear any other brand of gas, when my car was bolt on if I ran any other brand of gas Hess, Sheetz, BP etc... On the 2-3 shift it was just bust out and then finally shift at what seemed an eternity... But when I had 93 Shell it never would. Weird?
I ran chevron fuel previously. This time I ran some from the kangaroo station. Probably bad gas. I always run 93 octane.
Iat temps were way up too, I think about 20°.
I also just replaced my fpr, now I need to verify fuel pressure, possibly running leaner.
Can you feel any surging in 3rd even though it continues to pull hard?
I had a similar issue that effected 3rd gear @ WOT. It would pull hard but had a slight surge. I tried the things suggested here, fuel, timing but it only continued to get worse. Eventually it started to effect the top of 2nd gear and I felt like a bobble head in 3rd. New valve springs went in...no change.
Then I noticed the water pump started to leak. While I was in there I figured I should take a peek at the opti and bingo! Even though this car had only 34k miles, the factory opti had loose rotor screws. Reassembled using Loctite and its perfect to 6500 in 3rd.
Root cause, doing a cam swap and not replacing the O-rings on the optishaft.
It was 200 deg from the start to the finish. It only got up to 201 after the run ended. I did order a 160 deg thermostat, we'll see if that helps.
