what fuel injectors for an f1a procharger
what fuel injectors do you guys recommend for an f1a pro charger. ill be getting one soon and would like to go ahead and get my injectors. looking for 700+ rwhp engine is a 355 fully forged with diamond boost pistons. cc503 cam le2 heads stock intake and throttle body for now. and will a walbro 255 fuel pump be enough or will I need a dual setup thanks.
i did not even know fuel lines and rails had a hp limit but i guess it makes since. i was thinking about running about 700 hp on the street. i probably wont start at 700 but boost is addictive i know ill want turn up the boost eventually. and maybe using a 150 shot on the track that should bring me close to 1000 hp. i would rather buy stuff once than to buy something then find out i need bigger injectors and have to re buy them what is the limits of an f1a on pump gas.
for some reason there online store is not working at the moment but I did find this complete kit includes lines and the double fuel pump kit kind of expensive at 1800$ but I've already sunk a small fortune in to this car so what is another 1800$ lol
http://www.lonniesperformance.com/fbodyfuelsystems.htm
I have the Lonnies double pumper kit minus the lines/rails but I plan on upgrading perhaps next season. I sourced a nice set of modified rails/regulator so I just need to make the lines.
thanks for all the help I looked at your build and I thought I had some good stuff yours is better lol. I hope what I got is good enough for at least 700hp. the only thing I am real worried about is I forgot all about my mains and left them a 2 bolt. when I sent my block to the machine shop this is my first build so I guess ill have to remember that the next time I build something you live you learn. I am far enough along now I am thinking about doing a build thread.
I running 96's w/ twin 255's no problem modified rails, -8 feed in parallel and -6 return What size pullies are you going to run, 8 or 12 rib? May be selling my 12 rib system w/ new unused belt and SDCE bracket in the coming months. 3.85 blower and 7.65 crank.
Man-Crush Warning
If you are sticking with in tank 255/340lph pumps, go larger on the sticks. Otherwise, use the 80# sticks and a larger fuel pump capable of holding flow at high pressure.
Fancy injectors
http://injectordynamics.com/injectors/id1300/
Fancy injectors
Man-Crush Warning
Found these what you guys think
8 x 96lb Fuel Injectors Bosch EV1 Style Fit Ford GM V8 LT1 LS1 LS6 LSX 1000cc | eBay
