Buying a used Moser 12 bolt....
Old 12-01-2015, 08:16 AM
SwampWS6's Avatar
Default Buying a used Moser 12 bolt....
I posted in the gears and axles section but thought you guys would be quicker to respond.
What things should I look for as far as quality/usage?
I think Im getting a hell of a deal at $600 but it has 70k miles on it though. Are there certain things I need to expect to see/find? First rearend purchase so I am kinda lost on whats important or not......
Thanks a lot!
Old 12-01-2015, 09:56 AM
Village Troll
SS RRR's Avatar
check the axle bearings. see if there is any play in the axles. check the pinion shaft. see if there is any play with that. open the cover and check the wear pattern and to see if there's anything funky going on. 70K is nothing, unless all of that was spent hammering on it. did it come out of a manual or auto car?
Old 12-01-2015, 10:33 AM
SwampWS6's Avatar
Thanks for the tips. It came out of a auto car. 97 Z28 full suspension car. Stock motor beside SLP CAI.
Old 12-01-2015, 10:42 AM
Man-Crush Warning
Shownomercy's Avatar
If its four bolts to hold the TA on, I would pass.
Old 12-01-2015, 11:21 AM
SwampWS6's Avatar
Why? Care to explain?
Old 12-01-2015, 01:46 PM
waltsfastz's Avatar
They tend to loosen up. but for $600 you better jump on it before someone else does. That is cheap .
Old 12-01-2015, 01:49 PM
Fastbird93's Avatar
I wouldn't even ask questions at that price. Even if it was thrashed you'd still be saving money with a full rebuild.
Old 12-02-2015, 06:16 AM
Dirty_Bird's Avatar
For 600 bucks id buy it and rebuild it. Hell of a deal
Old 12-02-2015, 06:18 AM
Dirty_Bird's Avatar
Mine has yet to loosen up with the 4 bolts, i used the idustrial green loctite on those bolts. After a season of beating the **** outta it there still tight
Old 12-02-2015, 08:24 AM
SwampWS6's Avatar
I think its in fine condition. Its not blown up or anything, just been sitting for 3 years because of a busted trans. And if everyone is saying $600 is a steal, I think I can deal with the 4 bolts and using the industrial loctite......
Old 12-02-2015, 12:19 PM
Mystery Bird's Avatar
I have the four bolts and have only had to tighten them up once in two years. I will probably loctite them next spring.
Old 12-02-2015, 01:08 PM
SwampWS6's Avatar
What are the differences in a Moser 12 bolt and a Strange 12 bolt?
Old 12-03-2015, 10:06 AM
zz17iroc's Avatar
Same here, I've had mine over four years and still tight as can be. I'd jump on that deal!!
Truly the only difference is Strange's torque arm mount is the same as factory mount with the two long bolts.
Old 12-04-2015, 06:41 AM
Fastbird93's Avatar
I do believe stranges axle tubes are smaller than the Moser. If memory serves me the Strange has 2.5" axle tubes and the Moser has 3" axle tubes.
Old 12-04-2015, 08:37 AM
SwampWS6's Avatar
As long as it takes my BMR chassis mount torque arm
Well thats a good thing. I thought there was huge differences....
Old 12-04-2015, 09:27 AM
waltsfastz's Avatar
I Think your right on the axle tube sizes.
BTW have you bought it yet?
Old 12-06-2015, 05:57 PM
SwampWS6's Avatar
Yes I have the donor car. Just havent had time to take the things off it I need....
Quick Reply: Buying a used Moser 12 bolt....
