Exhaust manifold gasket
Old 12-10-2015, 11:55 PM
mr_adaya's Avatar
Default Exhaust manifold gasket
You guys, I have speed engineering lt1 headers from eBay and I am looking to replace my gaskets now. I was about to go about buying the Fel-pro pn #1406 for them, until I realized the port holes. Does it matter if the headers are circle holes, and the gaskets are not? What is anyone's gasket recommendations to whoever has these headers or so, and what I can do in the future to prevent these fat *** leaks.
Attached Thumbnails Exhaust manifold gasket-photo110.jpg   Exhaust manifold gasket-photo595.jpg
Old 12-11-2015, 12:11 AM
mr_adaya's Avatar
Or does it just have to match the D port heads?
Old 12-12-2015, 05:47 PM
lt1-xjs's Avatar
The gasket has to seal the flange, if the 1406 covers the header flange then use it. The header bolts need tightened between heat cycles 4-5 times. Just check the bolts daily to make sure they are snug before you start the car.
Old 12-13-2015, 01:24 PM
ringmaster72's Avatar
I prefer the Earls. http://www.jegs.com/i/Earl%26%23039%...9DA3B/10002/-1
Quick Reply: Exhaust manifold gasket
