Starting Engine Without Water Pump
Old 12-24-2015, 04:50 PM
Snorkelface's Avatar
Default Starting Engine Without Water Pump
I'm about ready to fire the car up after being down a few years due to a bad Opti. Since the water pump is the biggest and messiest pain in the butt, can I just crank the motor and make sure she fired up before putting it back on? I figured since it's driven off the cam and not the the accessory belt it would work fine. Any reason this would be a problem?
Old 12-24-2015, 04:54 PM
Cajun ELESS-ONE's Avatar
it will be fine. i did it on mine when i changed my opti to make sure it runs. only run it for about 10 seconds. thats all you need to make sure it will run. just remember to put your intake and maf on. it wont run right with the maf unplugged.
The following users liked this post:
FLUTHEDUDE (01-05-2021)
Catmaigne's Avatar
Nothing wrong with firing it up for a few seconds
Old 12-24-2015, 05:01 PM
Thanks guys, I appreciate the feedback!
Quick Reply: Starting Engine Without Water Pump
