255lph in line pump install, need fitting suggestions
Old 01-06-2016, 06:48 PM
lt1_80_corvette's Avatar
Default 255lph in line pump install, need fitting suggestions
http://www.jegs.com/webapp/wcs/store...=&pgGrp=search
I'm installing this inline pump and don't want to use the barb fittings. Jegs support didn't want to suggest anything " or it voids warranty... blah blah...."
I'm looking for compression fittings that would connect to 3/8 steel tube. Anyone have any part numbers?
Old 01-06-2016, 06:57 PM
Man-Crush Warning
Shownomercy's Avatar
Looks like an 044 knock off, which has straight ORB threads as well. Which if it is, they are wacky metric.. M18x1.5 inlet, M12x1.5 outlet
I would call jegs are bother then till they give you a spec sheet.
Old 01-06-2016, 07:04 PM
The inlets are 10mm x 1
I'm looking for a fitting that is 10mm x 1 to 3/8 compression that can hold 70psi
Old 01-06-2016, 07:30 PM
Man-Crush Warning
Will be a cluster of crap, but here, maybe this would work for you.
From steel fuel line
http://www.mcmaster.com/#52215k614/=10kjvbi
From female 3/8 NPT to 6an
Amazon.com: JEGS Performance Products 110333 -6AN Female to 3/8" NPT Male Adapter: Automotive Amazon.com: JEGS Performance Products 110333 -6AN Female to 3/8" NPT Male Adapter: Automotive
And finally 6an to the metric
http://www.summitracing.com/parts/rus-670470/overview/
Pricey.
Old 01-06-2016, 07:56 PM
Thanks Show, if I had to use the barb fitting, I would use the SS braided line to connect to the 3/8 hard line.
Do I need to double flare the the 3/8 steel line then slip the SD braided line onto it (lastly good clamp to secure)? I've never installed an inline pump before.
Old 01-06-2016, 08:59 PM
Man-Crush Warning
I would get that compression fitting I linked above and then a NPT fitting to barb. Then use a hose to connect to the fuel pump barbed fitting.
Personally, I would return it and do something intank but without knowing what your situation is, IDK if thats possible.
Quick Reply: 255lph in line pump install, need fitting suggestions
