95 Trans shuts down! HELP!!
Old 02-03-2016, 02:27 AM
Bodine1's Avatar
Exclamation 95 Trans shuts down! HELP!!
My son had his 95 T.A. away at college and it started shutting down on him while driving? I got it home and ran it for a while no problem... then I figured out that the car seems to die once it hits right around it's normal operating temp. Temp reads correct on dash and on a manual gauge so I'm stumped! Any Ideas where I should start? HELP!
Old 02-03-2016, 03:03 AM
hrcslam's Avatar
Data log. $60 OBD1 ALDL 16 PIN cable and some free software (scan9495 or $EE Hack).
Old 02-03-2016, 07:40 AM
myltwon's Avatar
Does the car want to fire back up after shutting off?
Old 02-03-2016, 08:28 AM
Huntr1117's Avatar
Data log is the way to go. I'm going to lean towards the problem being the opti. I know everyone says opti but my brothers car had the same symptoms before it completely went out. It would randomly shut off while driving, then it would run fine for a week. It just progressively got worse until it wouldn't start at all. I would also say check fuel pressure. Your pump could be going out.
ahritchie's Avatar
My guess is the either ICM is getting hot and acting up (do the ICM spacer mod or try a different ICM) or the optispark may be on the way out. I would check for the opti related codes or symptoms. Sometimes there's no codes however.
Symptoms:
* Car suddenly dies and won't restart
* Starts but immediately dies
* Extended cranking to start
* Rough idle
* Sputtering
* Backfiring
* Trouble reaching higher rpm
* Black smoke from exhaust
* Poor performance with car warmed up
* Weak plug wire spark
* Codes 16, 36, and 42 may be set
Old 02-04-2016, 01:40 AM
warriorcustoms's Avatar
ICM is My guess... My old IROC would shut off after I installed a new dizzy & come to find out it Didnt have any Dielectric grease under the module!!! Put some Dielectric on the module& it Never did it again!!! SUCKED *** pushin that 4000lb pig in the Rain By Myself when it did it the Last Time LoL
Take the ICM & Have Em test it like 5 times so itll heat up!!!
Quick Reply: 95 Trans shuts down! HELP!!
