After 20 years, it's time....
Pretty much spot on.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
I'll take the congrats!! It's long overdue.
__________________
wow I'm glad to see this car back, I remember seeing it in GMHTP. I thought it had died long ago, I'm in the process of doing a D1SC on my bone stock LT1 engine also and glad to see that I'm not completely insane. Hope it holds up..
Congrats on the rekindled interest. The same thing happened to me and I'm glad I rebuilt the beast.
And the silver LT1 Formula is truly the nicest body style ever made....keep us updated with your progress...
#32
Thanks and will do. Pulling the car off the lift this next week so I can pull the rearend and get the 4:30's replaced. The Callies crank is still a month out so it gives me time to get some other stuff done.
__________________
#34
It's nice to know you're rebuilding the LT1. I was in the same situation a few years back, when a pushrod gave out during dyno session. It came to a debate on either building a stroker 383, a 396 LT1, or go to the dark side,....long story short, I'm just about done with my 416 LS3 build! Anyhow, good luck with your new build.
#35
I had no hesitation making over 500 with the P1SC with the factory 2 bolt main block. I have yet to pull the engine down to check the bearings though. For this build however, I plan on making at least 800 out of the back of the engine to get the car consistently in the 9's. When compared to the cost of the crank, rod, and pistons, the splayed main caps is a relatively inexpensive upgrade.
Jon
__________________
#36
__________________
#38
I have seen many 2 bolt blocks produce more than 500 rwhp without any problems. You will not find a consistent answer when the 2 or the factory 4 bolt blocks become a limitation because there are too many variables., i.e., is the crank driving a supercharger, power adder such as a turbo, being punished by nitrous, and what rpm levels will the engine be seeing.
Jon
Jon
