Need help 1996 camaro lt1 cranks but won't start!
Old 03-04-2016, 08:42 PM
CamaroReaper777's Avatar
Exclamation Need help 1996 camaro lt1 cranks but won't start!
I just got done putting a new coolant sensor, and cleaned the throttle body of my LT1 Camaro (1996) and when it started, it ignited pefectly. But after about 5 mins of idle, it just cut off, no slow death or anything like that, just died. I checked for spark, air and fuel and I got it all, but when I try to crank it, it will rotate but not start. When I let go of the key it acts like it's bout to start but dies. Any and all help will be greatly appreciated.
Old 03-04-2016, 09:42 PM
Jaxem's Avatar
where did you check the spark and fuel?
Old 03-04-2016, 09:49 PM
I checked spark at the plug itself. I took the plug out and a buddy of mine cranked the engine and I checked for the spark. I used a stethoscope to hear the clicking in the injectors and the strong smell of fuel when I took out the plugs was another indicator of. And me possibly flooding the engine while trying to figure this issue out
Old 03-05-2016, 02:27 AM
hrcslam's Avatar
Ohm out the coolant sensor.
Old 03-05-2016, 02:36 AM
liketowork's Avatar
Default Need help 1996 camaro lt1 cranks but won't start!
The spark on the plug had to be blue not yellow if it's yellow it's the opti I just had the same thing happen to me. New opti went bad in 3 weeks Good luck
Old 03-05-2016, 08:58 AM
hrcslam's Avatar
That's not the opti. The cap and rotor? yes. Hope you didn't throw the old one away. Especially if it was OEM. The Mitsubishi sensors are the bees knees and need to be collected and kept.
Quick Reply: Need help 1996 camaro lt1 cranks but won't start!
