Best size drag radial for stock setup 94 z28
Old 04-17-2016, 11:20 PM
94lt14's Avatar
Default Best size drag radial for stock setup 94 z28
Buying a set of drag radials to go on my 94 z28 camaro need to know what size tire I can put under it on a 15in weld pro star 5.5 back spacing 8 wide
Old 04-17-2016, 11:30 PM
Newbomb's Avatar
M/T ET street S/S 275/60/15
Old 04-17-2016, 11:49 PM
94lt14's Avatar
Did you have to put the wheel spacers on the front ?
96LT1Z's Avatar
Go 275/50/15 you'll do better with a 26" tall tire compared to a 28"
Old 04-18-2016, 12:01 AM
94lt14's Avatar
Did you have to use the wheel spacers on the front ?
Old 04-18-2016, 06:39 AM
myltwon's Avatar
Iirc the back spacing for 15X8 is 5.5" and 15X10 is 7.5" been a while since I looked it up. You will have to run a spacer in the front for 3.5" wheels and grind the cooling fins off the rear calipers. Stay with a 26" tall tire, 28" will reduce your gearing and require rolling the fender lip and isn't needed at the power level.
Old 04-18-2016, 11:21 AM
Village Troll
SS RRR's Avatar
http://www.camaroz28.com/forums/whee...wheels-576054/
Old 04-18-2016, 08:49 PM
Puck's Avatar
275/50 is probably a better bet for a stock/bolton car.
Old 04-21-2016, 12:07 PM
IDriveChevy's Avatar
I ran a 255/50 on my bolt on car and had no issue cutting 1.6 60's. Same thing with a 275/50
Old 04-22-2016, 01:56 PM
Newbomb's Avatar
I did not need spacers.
Old 04-23-2016, 10:17 AM
myltwon's Avatar
sometimes lack of spacers is indicative of worn brakes or a faulty caliper
Old 04-28-2016, 01:21 AM
94lt14's Avatar
Will a 275/60/15 fit under my car
Old 04-28-2016, 11:12 AM
myltwon's Avatar
Yes but you will have to roll the quarter panel lip
Old 04-28-2016, 11:43 AM
lt1_2buku's Avatar
275/60r15 for me. Haven't rolled the fenders and haven't had any rubbing so far. Stock ride height.
Old 04-28-2016, 12:28 PM
myltwon's Avatar
On mine I had passengers in the back while running the 28s and drove around some. Heard a flapping sound and realized the fender lip had cut a chunk out of the edge of the tire all the way around. Not saying it will happen to everyone especially if you never load up the hatch or rear seats but it has to me and others.
Old 04-28-2016, 02:36 PM
lt1_2buku's Avatar
I may need to take a bat to mine just for good measure.
Old 04-28-2016, 03:00 PM
94lt14's Avatar
What back spacing do you have on your wheels I have the same wheels on the rear
Old 04-28-2016, 06:52 PM
Puck's Avatar
Take out the back seats and don't worry about it .
Can't fit anyone over 12y/o back there anyway LOL.
Old 04-28-2016, 07:25 PM
myltwon's Avatar
Lol so true
I did throw an lt1 block and iron heads n the hatch once. I swear it damn near drug the bumper lol
Old 04-29-2016, 12:50 PM
lt1_2buku's Avatar
Wheel is 15x8 with 5.5in back spacing.
Quick Reply: Best size drag radial for stock setup 94 z28
