400 horsepower
Old 05-04-2016, 12:16 AM
350 groundpounder's Avatar
Default 400 horsepower
Will a lt1 make 400 flywheel hp with CAI, airfoil, tb bypass, cc305 cam, 1.6 roller rockers, ewp, and 1 5/8 mac headers and a mail order tune? Curious what ppl think it will make.
Stock heads, throttle body and intake.
Old 05-04-2016, 12:40 AM
96LT1Z's Avatar
Sure, only one way to find out.
Old 05-04-2016, 05:11 AM
bufmatmuslepants's Avatar
EWP adds 100 hp, and the airfoil adds 25, so that's 400.
Cc305 might get you to 330rwhp, you'd need 348 to have 400 at the crank with 13% drivetrain loss through an m6, so you might come up a tad short.
Old 05-04-2016, 10:35 AM
Yeah i counted on the ewp adding 100hp!!!! But yeah 380-390hp would be nice. I read an article where the hotcam made 425 crank. The cc305 has more lift and duration than the hotcam when run with 1.6 rockers. But my shade tree jerry rig build should at least get 375crank through a m6?
Old 05-04-2016, 10:41 AM
Man-Crush Warning
Shownomercy's Avatar
No one races dynos and no one really cares bout FWHp
Race your car, see trap speed, be happy.
Old 05-04-2016, 11:05 AM
Hoping for 110 trap with my m6. Traps 101-102 basically stock right now.
Old 05-04-2016, 05:25 PM
myltwon's Avatar
110mph trap is doable assuming the tune is good and you drive great.
Old 05-04-2016, 08:19 PM
NewOrleansLT1's Avatar
That's hot cam kit with 425hp is with the LT4 heads and intake..
Old 05-05-2016, 09:59 AM
HellTeeOne's Avatar
It's not difficult to make 400 flywheel with a "cam-only" LT1, but you'd likely need more cam than the CC305.
Years ago I made 352rw SAE through a M6 and 10-bolt with an XE224/236, which is right around 400 flywheel if you use the 13% driveline loss math.
The 425-hp LT4 top-end kit is a waste of money, you can do much better than that for what it costs.
Old 05-05-2016, 10:12 AM
sweetbmxrider's Avatar
You'll twist the chassis off the line for sure.
Old 05-05-2016, 12:00 PM
Village Troll
SS RRR's Avatar
Newp. I think bolt on stuff with rockers makes around 310rwhp if not a few more? With the cam, maybe 340 or a few horsies more. You need ported heads to support the cam to get anywhere higher than that, and even with that cam and good heads you probably won't break the 400 mark. It's a few degrees off a hot cam. I don't ever recall anyone breaking the 400rwhp mark with one including ported heads.
Old 05-05-2016, 12:20 PM
I would be happy with 340rwhp through my m6 with just cam and stock heads. If we use the 15% loss, that would equall 400 flywheel. Im doing ewp and rr's so it should be close. I would be happy with 380ish also. And its a streetable cam with a 114lsa. Yeah 400 rwhp i would expect to need le2 heads and a pretty big cam.
Old 05-05-2016, 12:28 PM
StealthFormula's Avatar
I'd venture a guess that your mods are gonna give you ~100 flywheel hp over stock so that's 375ish at the fly. With a slightly larger cam and 1-3/4" LT's then 400 flywheel would be more realistic IMO. None of that really matters tho, just as long as you enjoy the car and whatnot.
Old 05-05-2016, 02:57 PM
Its a 96 so i started out at 285hp yee haaa lol. Yeah i figure 375 will be the minimum hp i should get. I dont see the mac mids restricting hp that much at this level. Should help make nice torque with the 1 5/8 primaries. You nailed it, i will love driving it. I already love the car with stock power. Cant complain, got the cam and lifters new for $160. If i wasn't on a budget i would def do a custom billet cam from Lloyd and some le1 heads and have a very streetable 350-360rw.
Old 05-05-2016, 04:26 PM
BALLSS's Avatar
OP
you doing valve springs also?
you need to.
cam only, stock heads maybe around 325...could be less rwhp
whatever tune you get will play a big part in the HP gain with just cam and your other mods
Old 05-05-2016, 04:39 PM
Yes valve springs, 1.6 rockers, hardened pushrods, cam, ewp, mac mids, solomon tune. Prob the thinner fel pro gaskets to bump compression also. Im thinking 330rw.
Old 05-05-2016, 07:13 PM
Should def be fun. I always tell myself if I buy a second LT1 car I'm gonna get a 6-speed and toss in headers, cam and gears and call it a day. For the $$$ you did real well.
Old 05-06-2016, 06:49 AM
110 trap can be done without a cam, you just need to shift right. If I put a cam in my car and it only trapped 110 I'd burn it to the ground and get a Prius.
Old 05-06-2016, 08:21 AM
Lmao. That's funny i was telling my brother if it doesn't trap 110 im selling the whole car for 1200!
Old 05-17-2016, 10:51 PM
ElkySS's Avatar
My old motor made 363rwhp with an Ai 226/234 cam kit and Impala SS head gaskets through a T56 and a Moser 12 bolt. I'd look into Advanced Induction if I were you. That dyno number suprised everyone.
Quick Reply: 400 horsepower
