Keep blowing exhaust gaskets!! Back pressure issue??
So I've blown out 3 Y-pipe collector flange gaskets within a month and half! I haven't skimped out on quality gaskets, I've been using Hedman gaskets which are $8 from O'Reillys. I haven't over/under tightened the bolt/nut that hold the flanges together. I've snugged them down and put a dab of thread locker on the bolt so they wouldn't back off. I have Pacesetter mid length's and no cat. I was thinking that since I still have stock exhaust I have too much back pressure. My car currently sounds like *** because of this issue, HELP!
Edit: Only other performance modifications are 1.6 rr's, cai, egr delete, smog pump delete,
I don't condone doing this on all vehicles but if you have an exhaust flange that's giving you fits and a new gasket helps but doesn't cure it buy some copper RTV and lay a bead on the gasket then assemble it. Let it dry thoroughly before starting the vehicle though.
I used to have to RTV my head slip fit connections because no matter what happened the leaked-until I used copper RTV.
I use Percy's Seal-4-Good Header Gaskets for the LT1. Part number 66031 on Summit's site.
https://www.summitracing.com/parts/php-66031
Get some ARP 5/16 12pt 1" stainless steel header bolts.
Zero problems with leaks or the bolts loosing up.
Also....tighten the bolts in the center of the flange first, then the ends last(center out).
**** even using a true flange I use that stuff too. Just to make sure. Some of the best stuff Permatex ever created IMO. Comes off easy too!
He's talking about the collector gaskets... not the header gaskets.
Update- Got some soft metal gaskets and some copper Rtv. Put a tiny bead of the copper rtv around the gaskets. So far so good! Thanks for all the helpful hints and suggestions. Really appreciate it!
Village Troll
I would not use RTV on exhaust components. If there is a gap where exhaust gasses are passing and you are trying to seal it with silicone it will only blow out in a short while. no way silicone can withstand that kind of heat for very long. You need to find out if your flanges are true before trying the RTV thing, IMO. Are you running catalytic converters?
Originally Posted by atlantadan
Remflex 2042's. I've never had them blow out and I've used them on all sorts of heads.
I will update this tomorrow when the new exhaust and gaskets go in. Thanks for the help guys.
