Oil pump drive gear with cam swap
Take it out and look at the gear. If the teeth are in good nick, put it back in and don't worry about it. Loads of people running aftermarket cams with OEM drives with zero issues.
I'm not sure what the OPs cam would need. I do remember some issues where it was believed the stock oil pump drive gear would not work. I can't remember the specifics though.
In this link check out NightTrain66(LE) post 21. If you have a cast gear, the stock drive gear will be fine. If the gear is billet with the cam, then you will need a billet drive gear.
http://www.camaroz28.com/forums/lt1-...-drive-400727/
