Spark plug wire routing
I currently have an OTVC kit that uses the valve cover bolts to hold the looms. I really want to run composite vette valve covers but I can't with my current wire setup.
Does anyone have any pics of plug wires mounted in an other than stock location that doesn't use the valve cover bolts?
I have basically this same setup but with the LT4 composite valve covers. The aluminum brackets part 50-82494 appear to work with the stock valve covers BUT they did not work for me with the LT4's, wasn't enough clearance. I had to do some modifications to make it work. It was a PITA but it works.
