Lt1 timing sounds off/ runs rich
Old 10-11-2016, 09:54 PM
berarlu18004's Avatar
Default Lt1 timing sounds off/ runs rich
Hi everyone i was wondering if you guys could give me some trouble shooting tips for trying to figure out what is wrong with my car. It is a 1994 camaro z28 A4. The trouble i am having is that there is a weird vibration at idle/ timing sounds off. The car also smells very rich at idle and i can smell it inside the car with the windows down. i also noticed on the intake there is a 1 inch metal tube coming off of it where i'd assume a hose would connect to. The wire harness is also very butchered/taped up with a few connectors not connected to anything on it. I basically have no history on the car. Thank you for all the help in advance.
Old 10-11-2016, 10:05 PM
ElkySS's Avatar
Fix what you know is wrong. Then go from there.
Also, some pics would help.
Old 10-12-2016, 06:37 AM
myltwon's Avatar
Like stated taking pics would help.
Is it throwing a check engine light?
Old 10-12-2016, 11:31 PM
I posted pictures last night but it said i need moderator approval for the post to be public. Still hasn't been approved?
Old 10-13-2016, 08:40 AM
thetransamkid's Avatar
If the car had an EGR delete done that would explain the loose connectors and why it is running rich. I know mine runs a little rich with the EGR delete because I am still on the stock tune, this would also explain a check engine light.
Old 10-13-2016, 02:32 PM
How would i be able to tell if the egr system has been deleted? The check engine light sometimes comes on at idle but it hasnt other than that. When i got the car it came with an extra pcm, alternator, and intake manifold.
Old 10-18-2016, 09:46 AM
My Check engine light turns on and off like you'res also. An egr delete would explain the open nipples on the intake manifold. They should have been capped off, look for a smog pump and a catalytic converter underneath the car. I'd get a code reader to pull the codes.
Old 10-18-2016, 10:28 AM
Yeah i checked and my car definitely has an egr delete done. Yeah the nipples are capped off. what are all the connections/tubes that are supposed to be connected to the intake. im still trying to figure out the open tube on the intake.
Quick Reply: Lt1 timing sounds off/ runs rich
