New truck 5.3 cam thing!
Hey guys
am shopping for a cam for my new 2015 5.3 truck, its a new thing to me and haven't seen enough results of a cam swap out of these new gen motors.. direct port injection.
It would be very helpful if experts and experienced people comment on the bellow
How to cam a new gen 5.3 direct port motor?
How is the 1.8 rocker ratio affect the power (extra lift)
How does overlap effect the power in these motors?
Thanks & appreciate your feedback
You'd have more luck in the Gen 5 internal section, but I'll offer what I would do. Call Advanced Induction in NC, you can go over your setup and tell them what you want and they will custom make you a cam to fit your needs. If you want an off the shelf grind, give us some more details on the setup. 5.3, heads? Intake? N/A, boost, nitrous? Drag racing, road racing/AX, street car? What trans?
It's a 2015, post it in the gen V section.
If you're looking for more power out of a stock gen v motor and still want it to be drivable as a daily (I'm assuming since it's a 2015 truck), look into Whipple's supercharger packages. They're pricey but you basically just have to pull the intake manifold and I've read about some impressive gains with them while retaining drivability, just an option that's out there.
I'm not a big fan of boosting a stock motor (or boost in general), but considering it's a new engine and not old and tired, and you're not pushing a ton of boost through it, you should be fine for a nice power increase. Then later down the road with a proper build, you can bump the boost up and make some serious power. I just hope you're not worried about your powertrain warranty as with either a supercharger or cam, you'll void it. 6.2's are warranty friendly powerhouses, best of luck!
