Fbody lt1 WC t5 from v6/or tko 500
I dont want a 6 speed just getting that out of the way i like the t56 dont want it though im throwing ether a wc t5 swap from a v6 fbody with 26 spline with a 3rd gen clutch and a lt1 flywheel same results would be with a tko id do that swap aftwr some money saved up but i csn afford a decent t5 swap for now what do i need nessicarily besides cross member snd GM bellhousing?
T5 4th gen
Its behind a lt1 in a 4th gen i know that ill have to get the right tyoe of fly wheel and the crossmember has to go a little further back and actually ive heard and seen t5s hold a little bit of power especially rhe WC my buddy had a wc t5 behind his 800 hp mustang so its really up to the clutch and flywheel set up i know i need a gm bellhousing for it all to bold up right and the 4th gen t5 has a 26 spline soo if you have so insight on whats nessisary to get it to work
I have a T5 WC behind my LT1 but it is in a 2500lbs car with 195 tires. I would fear you would break the T5 in a 4th gen. TKO500 should be stout enough or a Jerico 4 spd.
OP
I would go with the TKO. The T5 is weak for a stock LT1...H/C LT1 it will have a short life if you drive it aggressive (read clutch dumps). If a stock motor and you just "drive it around" it would "work"...just not take much abuse
With that said IDK what is involved in mating a TKO to a LT1 but in the end could likely cost more than a T56
T-56 is an easy swap. I would skip the T-5 unless you sent it to astro gear. Then you still have to get it mounted. A-5 conversions are not cheap. T-56 can be still had for $1200-1500 for a lt1. Makes it easy to unbolt and bolt in. You save cash on things like the driveshaft and not making mounts. TKO is close but then you will spend the money everywhere else. Not to mention if you need a working speedometer. My vote T-56
T56 out of the question
Well i dont want a 6 speed like a said but that 4 soeed idea sounds crazy im going to eventually the 4th gen firebird as a road race car ill never hit 6th gear on these tracks so a 5 speed is oerfect so what would i need besides a bellhousing and probably a shorter drive shaft custom made for the tko 600 since the tko is brand new its better then buy a parts car with a t56 that already has the swap cus no matter what ive gotta rebuild and buy new clutch flywheel everything to go with t56 so again thats out of the wuestion its not about the price its about what i want out of my ride i want the 5 speed tk0 500 or 600 now i heard actually that is had the cable to sync to my car and id just have to edit the pcm which i planed on doing since i have lt1 edit so id need a new drive shaft the stell bellhousing a pro 5.0 shifter most likely a 3rd gen clutch and the right flywheel to fit on the lt1 thatll fot with the clutch that works with the tk0 what else
Thanks ******
Thanks ****** ill probably see what they have for 4th gen fbody im sure all i really need would be the custom drive shaft everything else i can pretty much find on my own. In the end ill end up with a tk0 500 or 600 they are the best bet for a 5 speed brand new and great gear set very close to that ofbthe t56 gear set ud personally rather haveb5 gears cus to me ifni dont have something with 700 hp or more i dont need 6 gears
I know TKO can work with a LT1. Keisler did a TKO install into a 95 B-body. IDK what bell housing or FW/clutch but it was a push vs pull clutch like the LT1/T56 uses
TKO is a stout tranny and IIRC you have options on gear ratio
Dennys makes a good DS. What I went with on my A4-T56 swap in my B-body. I went with 1350 yokes also
Ive been in the same boat for a bit. Want a stick but not really into a 6 speed. The problem is that the t-5 is crap. Even the stock 305 could break them. The problem is in the case so even a gear upgrade wont get it very far. Tko is really the only viable option, but the conversion can be a pain, plus the expense. Mine is a third gen Iroc with an lt1 swap.
Ive kinda resigned myself to an auto for now and will look into other options in the future.
Nothing wrong with going TKO 500 or 600...just a more complicated and expensive path. TKO has more girth to the tranny case so some tunnel massaging is likely needed
I have 4:10's and only see 6th if I can drive a "sustained" 65+ MPH. On the street its a 4 speed. Hwy 5. At 80 mph in 6th I am just under 2k RPM on a 27" tire
It is not mandatory you use 6th in a T56. The shift pattern of 1-5 is the same as a TKO. T56 is plug & play for a LT1 and will hold a bunch of power
T56 has its faults
Not sure what "faults" the T56 has....but do agree 20+ year old manual transmission that is not made new anymore and was likely not driven by your grand mother will need some form of rebuild. Likely crap shoot buying a used one but they are around and $1500 generally is what it costs for a "rebuild" so add that to whatever cost for the tranny itself. Just a T56 is way more plug & play for your install
TKO has been done on a LT1...IDK what was involved but the one I am aware of uses a push clutch.
Just get a t56, scratch out the 6 on the shift **** and on the name, get a skip shift eliminator plug, and viola you have a 5 speed t5. 5th gear on all of the transmissions mentioned is overdrive, with 4th being 1:1. A t56 just has 2 overdrive gears, 5 and 6, for fuel economy on the highway. Just don't use 6th if you don't want it, it has nothing to do with a 700hp car or a 150hp Honda Civic, the added gear just drops rpm on the highway to save gas. Just like the stupid skip shift, saves gas. Top speed comes in 5th, not 6th, 6th is for gas mileage.
