Public Service Announcement
Village Troll
Always use jackstands, folks, no matter how quick the job is. This was from a floorjack I've had for more than 10 years. It worked fine raising the car to put on stands, but once that happened it started coming down before releasing the pressure. If you are ***** deep under the car not paying attention and this happened you would have most likely been trapped. Just FYI...
Amen on the jack thing....admit-tingly I am guilty of "taking a quick look" while floor jack is holding car when I was younger & dumber....my floor jack is at least 50 years old, Craftsman
Have always worked on all my cars and when kids were young and always wanted to help Dad I said never get under a car held up by a jack only. They both, now grown, still say when I work on car "Dad use the jack stands and chalk the tire".
I would go even further and say to always use jackstands even when you aren't under the car. It would suck to be changing brakes and have the jack start releasing on you with the wheel off.
Village Troll
All fine and good until you have to replace something on the susp after snapping an axle or tie rod or... You into gunz and brodozers now, brah?
Seriously guys, chock and jack stands EVERY TIME.
Wifes Corolla fell off the scissor jack when the behind the wheel wasn't enough. Wheel was off doing the brakes and I was sitting on the floor next to it with my left leg under the car. Had just moved so didn't have jack stands, thought the chock would be fine for a quick brake job. Rotor karate-chopped the cement a split second after I jumped out the way. Scary stuff!
