A lot more damage then I was hoping for
http://imgur.com/a/Y86at
Im guessing these heads can't be saved? Not really sure where to go from here. Looks like I'll be looking for a new motor on craigslist.
As long as they can press a new seat in I think you will be fine. It has been years since I had this kind of work done so not sure if the cost would outweigh replacing the head.
Edit: looked a little harder and now leaning more towards nope
These heads are a set of LE1 so if they can be fixed they def need to be. Ill be turning them over to my local machine shop monday to see what they say. Looks like im either hunting for a new short block or having one built now
yup it was a hardened pushrod.
also looks like the passenger side got some damage also
http://imgur.com/a/QeiLD
anyone know any easy way to pull the crank hub/balancer with the motor out of the car. Cant figure out a way to get it to not spin
Re: Maabco. Bought one from them for my last wagon. Put a cam in it and some stock aluminum heads and ran the snot out of it for about a year before I sold the car. Never had a hiccup. Good oil pressure, good compression, never a problem. The current owner reports the same and its been 5 years now
Ellewin is regarded as about the best LT1 builder out there. IIRC he charges $1500 for a motor build + parts.
I bought a Golen 383 4 bolt forged short block for Golen 11 years ago. runs strong still so no complaints
Karl or Golen are certainly going to be more than MAABCO
FWIW I also bought a $1000 motor for my Ford 302 from a online builder and it "eventually" worked fine although I did have to immediately send it back for a rod knock. They did warranty it. The shipping cost though was on me.
Took the heads to the local machine shop and he says they cant fix them and they probably shouldnt be fixed. Also he said the valves were all making contact with the pistons.
So there goes the whole lt1 motor. Not sure what to do now
