Lt1 no crank - LS1TECH
Lt1 no crank
Thread Tools Search this Thread
Old 03-20-2017, 03:13 PM   #1
Default Lt1 no crank
94 z28 with a no crank issue. Car has always started up and ran fine. It sat for a couple weeks, so I started it up Thursday night and let it idle for awhile. Turned it off, unhooked battery, went home. Next morning I used the battery to start another car. Then put battery back into the camaro and now I'm getting nothing. No crank, no click, no nothing. Fuel pump primes, and all lights/accessories come on and work as they did before. Vats has already been bypassed. Only difference is that now when I turn the key on, my check engine light, and check gauges light come on. Low trac light also comes on and goes off when I turn the key to start, let off key and low trac light is back on. I've checked all fuses, and swapped out the starter/theft deterrent relay with a known good one, and the starter itself with a good one. Can't scan the car, nor can I check voltage at the purple wire at the moment. Any other ideas in the meantime?
KyleW707 is offline   Reply With Quote
Old 03-20-2017, 03:38 PM   #2
What is the voltage on the battery?
atlantadan is offline   Reply With Quote
Old 03-20-2017, 03:52 PM   #3
Battery is brand new
Old 03-20-2017, 05:47 PM   #4
Quote:
Does not matter. What is the voltage? I've had more than one new battery go belly-up in short order.
Old 03-20-2017, 06:31 PM   #5
myltwon's Avatar
Age =/= condition
plenty of new stuff is junk straight out of the box.
myltwon is offline   Reply With Quote
Old 03-20-2017, 06:50 PM   #6
It shows correct voltage. I can take it out and put it in another car and it starts up right away like it should. I can also put another good battery in the camar and same problem persists. It's not a battery issue.
Old 03-20-2017, 07:35 PM   #7
myltwon's Avatar
possibly a bad ignition switch
Old 03-20-2017, 07:44 PM   #8
I began to check that. Didn't have time to get the switch off today and look at it, but I did unplug the pigtails, and they're not burnt. Will continue with that tomorrow.
Old 03-20-2017, 09:03 PM   #9
Spartan7's Avatar
Make sure your battery connections are clean and tight. I had a similar issue with my truck once, everything turned on like normal but nothing from starter. It was just a loose positive cable.
Spartan7 is online now   Reply With Quote
Old 03-20-2017, 09:20 PM   #10
Cables and battery itself are clean, all grounds good also, but now that you mention it, I did use a different bolt for the positive cable when I put the battery back in Friday morning, and it had some rust on it. I'll have to check it out tomorrow.
Old 03-21-2017, 06:28 AM   #11
shbox's Avatar
Quote:
x2. With your symptoms/explanation, it is probably a connection issue.
shbox is offline   Reply With Quote
Old 03-21-2017, 06:41 AM   #12
Did you check for voltage at the starter terminal?
moehorsepower is offline   Reply With Quote
Old 03-21-2017, 06:55 AM   #13
myltwon's Avatar
that seems more likely than my previous assumption. More than likely you have enough contact to turn on some accessories but not Tp actually power anything that starts the vehicle.
Old 03-21-2017, 02:41 PM   #14
No Moe, I didn't get to check voltage. Accidentally left my multimeter 350 miles away. You actually tuned the pcm for said car. I have another one I'll be sending you sometime soon. Anyway, I got called to work out of town late last night, so the issue will have to wait another week or two when I get back to be resolved. I'll post back here though when I get to try these other things. Thanks guys.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
