Looking for a Cam recommendation
I decided to refresh the T/A's motor so now I'm looking for cam suggestions while still saving up for a 'proper ' LS3 for it. I will be going ahead with the wild 6L80E at the same time as this.
Did the top end build with a CC305 & AFR heads back in 2002- 100k miles ago, and looking to extend it's life and then plan on selling this engine once the LS3 shows up.
Here's the other main hardware assuming (hoping) the block stays a 350ci:
speed density (if that matters)
OEM crank & pistons
AFR/TPiS 195cc heads (refreshed)
Crane Gold 1.6rr's
custom 6L80E trans
3.73's
thanks!
OEM crank & pistons
Crane Gold 1.6rr's
custom 6L80E trans
3.73's
thanks!
I ran a custom Comp grind in my old 350 and really liked it. Paired with AFR 180's. Great all-around street cam. "LT3312/3314/HR112+5". Specs are 212/224 Duration @ 0.050. 487/502 Lift (1.5 ratio), 112LSA with 5 Deg Advance.
I've got it sitting on the shelf in the garage, too. Ran it for about 1000 miles before I pulled the trigger on the ERE 383 (the cam is about 9 months old. Been on the shelf for 6 of those 9). $100 and its yours.
Edit: how it sounds at idle
Edit:
100k miles from a cam swap on a lt1 with no spun bearings? That's impressive! I have 560 miles on my cam swap and would be happy if it runs for another 10-30k. AFR heads, ls3's.......the thing im learning is on the street torque is king. Next build has to be at least a 383. I have a 215/224 .533 lift LE speced cam with stock heads and i feel its plenty fast enough for street cruising. Makes great torque but i would love a 383 with ported heads built especially for torque fun.
SS RRR........My oil pressure is 60psi cold, 40psi at 1500rpm warmed up. Doesn't drop to 20psi until its idling at 800rpm. Does this reflect cam bearing health? I mean where does the oil pressure sensor get its reading from? Ideally it would have been nice to have new cam bearings but the shortblock stayed in the car during the build.
I agree with the others.....keep the same cam and worry about the power gains with the ls3!!!!!!
Village Troll
Village Troll
Does it at least help answer your question? Just remember when oil is cold it is much thicker and will produce a higher pressure than when warm. The readings you supplied are normal for our engines.
It does, your advice is always appreciated. Good to know my engine appears to be in decent shape for 100k. I picked a good cam in the fact that i dont have to strees the bearings reving past 5800rpm for max power. Car pulls hard from 2500-5500. 215/224 cam is great for a semi tired shortblock.
But I also want to keep this engine running to sort out any bugs the new trans may have so when the LS3 goes in, there's no surprises.
