1996 z28 camaro high idle
Old 03-27-2017, 08:13 PM
Nealennis's Avatar
Default 1996 z28 camaro high idle
I've replaced a few hoses, iac valve, cleaned throttle body replaced most of the vacuum system and still get the check engine light it idles in park between 850 and 1000 and in drive at 750 any suggestions
Old 03-28-2017, 08:11 AM
Gangly's Avatar
Trying to track down a cause for high idle can be a PITA, but a quick and easy check is the vacuum lines on the intake. Make sure none of the intake vacuum lines broke/cracked during the install of other components.
Old 03-28-2017, 02:54 PM
Nealennis's Avatar
OK I was thinking of replacing all the hoses on it it's just hard to and im going to need a full day to get it apart buy the hoses and install the new but I'll try that
Old 03-28-2017, 04:16 PM
Nealennis's Avatar
And everything I've read on it have rpmsome of like 1500 and 2000 and surging mine doesn't do any of that it generally runs good
Nealennis's Avatar
Old 03-28-2017, 05:53 PM
Village Troll
SS RRR's Avatar
Do you know what the SES light is from? It could be the throttle position sensor is out of whack. Have you messed with the blade stop screw on the throttle body?
Old 04-05-2017, 08:51 PM
Nealennis's Avatar
I'm getting p0157 and p0507 and I also read maybe the o2 sensor I check fuses
Old 04-05-2017, 08:53 PM
Nealennis's Avatar
No I haven't messed with it and how do I know it's the tps
Quick Reply: 1996 z28 camaro high idle
