gears gears
Old 09-23-2004, 10:13 PM
Pavlock Performance's Avatar
Default gears gears
wondering what gear to buy. mine came with the 3.23 so do i buy the 2 series or the 3 series??? this is going to be a track only car so would 3.73's or 4.10's be better with more results for the long run with out having to switch gears again???
Old 09-23-2004, 10:18 PM
LT1Burnout's Avatar
do u have an A4 or an M5?? A4 i would say 3:73, M5 i would suggest 4:10's.. also, im pretty sure its a series 3 carrier
Old 09-23-2004, 10:34 PM
Default a4
its an a4 soon to be th350 with around a 4000-4500 stall
Old 09-23-2004, 10:42 PM
2MuchRiceMakesMeSick's Avatar
Depends on what you want to do with the car. Do you plan on all motor? Or pumping the gass into it? Or super/turbo charger?
Old 09-23-2004, 10:53 PM
ShadowLvr's Avatar
Hey, getting rid of your 3.23's? And would that fit in my 96 Fleetwood?
Old 09-24-2004, 11:32 AM
well it gonna be all motor but how do i know which carrier????
Old 09-24-2004, 01:21 PM
DietCoke's Avatar
3.23 is a 3 series carrier
Old 09-24-2004, 01:22 PM
Default coo
thanks alot!
Old 09-24-2004, 05:02 PM
Strahley's Avatar
A common choice is 3.73s for an automatic
Old 09-24-2004, 05:43 PM
96capricemgr's Avatar
The Fleetwood has a 8.5" axle and probably 2.93s out back(3.43s a towing option), the f-body used a 7.625 axle, so the gears will not fit, for that small a change in ratio it wouldn't be worth the effort either. I just put 3.42s in my Caprice, nice imporvement over the 2.93s and still civil even at high speeds.
On the f-body question, forget the exact ratio of the th350s first gear but I believe it is less than the 4L60Es 3.06, so just putting that tranny in you are losing a little launch gearing. If the car is going to be fast enough to make it worth swapping out the OD tranny then maybe you need to consider the combination of trap speed/stall/tire height/projected rev limit, then you can look and see just how aggressive you can get with the gears.
Old 09-24-2004, 08:14 PM
I agree that is a common size. I went with 3.89s
Old 09-25-2004, 10:09 AM
ShadowLvr's Avatar
Not even a 2.93. I'm currently a 2.56 rear end. Regular Fleetwood, not the Fleetwood Brougham.
Old 09-25-2004, 08:25 PM
the th350 is like a 2.56 i thought? not too sure. but im told it is lighter plus my a4 is old and needs rebuilt and a th350 with a good stall is cheaper than the 700 and most cases stronger. but im thinking the th350 route, with 3.73's with around a 3500-4000 stall . "new motor being built". what do you guys think??
Quick Reply: gears gears
