How much power can the stock rear end on a 95 Z28 A4 handle?
Old 11-21-2004, 02:43 AM
Cerwin Vega Fan's Avatar
Question How much power can the stock rear end on a 95 Z28 A4 handle?
In theory how much power can the rear end take before needing to upgrade to a 12 bolt? I'm talking mainly street driving and no use of slicks.
Old 11-21-2004, 03:04 AM
TwoFast4Lv's Avatar
alot as long as you take care of it
Old 11-21-2004, 06:09 AM
Mike Comp T/A #57's Avatar
I'm still running a stock 10 bolt with 3.23 gears
Attached Thumbnails How much power can the stock rear end on a 95 Z28 A4 handle?-wheelsup.jpg
Old 11-21-2004, 08:47 AM
METALBEAST's Avatar
Your stock 10 bolt should be fine if you don't plan on using street slicks.
Old 11-21-2004, 09:45 AM
Snow Dog's Avatar
well the ten bolt can handle as much power as you can make. its the launching that they cant take. so if your not planning on dragging it much dont worry about the rear. your tires most likely wont hook good enough of the street to damage anything. if they do then sorry man time to upgrade.
i always go at it like this. if your not building a purpose built drag car or one thats going to the track every weekend getting the crap beat out of it, then dont worry about things like that til they cause problems. just be forewarned about their weakness.
Old 11-21-2004, 12:44 PM
Moderator
BizZzatch350's Avatar
Your an auto, it'll last a good while. I have 3 friends that went 10s on theirs, all TH350 cars.
Old 11-21-2004, 01:31 PM
Ls1LikeNoOther's Avatar
just let the tires slip a little bit at the start you will be fine.besides unless you run a big converter or you have a 6 speed car if you try to dead hook your car is gunna fall on its face anyways...Let the tires spin a lil off the start and run like a bitch out the back door!
Old 11-22-2004, 01:36 AM
Dexter93's Avatar
Id agree no launching on drag radials or slicks and you'll be fine.
Old 11-22-2004, 12:45 PM
Moderator
The auto will die before the 10 bolt, all my friends that went 10s on their 10 bolts were on ET streets or ET drags.
Old 11-22-2004, 12:54 PM
Gangly's Avatar
with an auto, you can launch on whatever tires you want and you should definately be safe running low 11's. Several people have ran 10's with it but thats about the limit on the rear ends and thats if the shop did a good job installing them.
Old 11-22-2004, 01:38 PM
ou812/z28's Avatar
i made it to 10.40's and every 3 passes i would have to put gears in it r a center section. now i have a 12 bolt and run 10teens with 1.38's and the 10 bolt went a best of 1.41 short time.
Old 11-22-2004, 01:56 PM
TSAEB's Avatar
the axles are very strong its the internals i would say will go.
Old 11-22-2004, 08:48 PM
TwoFast4Lv's Avatar
I agree. as long as it hooks good they will live. it is when you are not hooking good and they chatter that they get torn up. Lost three teeth one night like that.
Ran mine deep into the 11s on one at 3,750Lbs
Quick Reply: How much power can the stock rear end on a 95 Z28 A4 handle?
