Degreeing Camshaft Help - LS1TECH
Thread Tools Search this Thread
Old 08-04-2005, 01:15 AM   #1
Default Degreeing Camshaft Help
I will be recieving my LE AFR heads, and my Bauer cam soon, for my 383 lt1, and wanted to double check the degreeing of the camshaft, to make sure everything is put together properly. I searched various sites that explain how this is done, the problem is they all show how to do it with the heads on the block, but my heads are off the engine. Can anyone please be kind enough to explain to me how this is done. I already purchased a cam degree kit. Thank You for your time, it is very much appreciated.
wicked383bird is offline   Reply With Quote
Old 08-04-2005, 12:55 PM   #2
anyone?
Old 08-04-2005, 07:33 PM   #3
Jordan57's Avatar
we just set the timing set on and lined everything up dot to dot and all was well. no idea how to use an actual degree wheel.
Jordan57 is offline   Reply With Quote
Old 08-04-2005, 08:57 PM   #4
ellokote5's Avatar
you just need to bolt a plate with a bolt using the head bolts to find true top dead center (Where the piston stops)
ellokote5 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
cam degree?? camarozz383 Generation IV External Engine 0 01-29-2014 08:05 PM
LE 21 degree trickflows and what cam? quientelle LT1-LT4 Modifications 9 08-06-2012 07:51 PM
people tell me my cam sucks for my 383 Why??? LSXFEIN Generation III Internal Engine 32 05-11-2012 02:36 PM
Need help finding specs on Custom Grind Nu-Tek camshaft! meangbody LT1-LT4 Modifications 20 04-03-2011 04:18 PM
IVC calculation haacer LT1-LT4 Modifications 2 07-14-2009 05:00 PM
Tags
cam, degreeing, lt1, lt4, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
