97 LT-1 WS6 or 98 LS-1 Trans Am ?
Old 08-10-2005, 02:36 PM
Ibrahia's Avatar
Default 97 LT-1 WS6 or 98 LS-1 Trans Am ?
So i'm looking for my first F-body, hopefully getting it pretty soon but now i can't decide which one. I've come across two that i will be going to take a look at this weekend. one is a 1997 Trans AM WS6 with 74k and the other is a 98 Trans Am (non WS6) with 79k. both cars have the M6 transmission. both are green. T-tops. and i am torn as to which one i would take. i'm steering towards the 97 WS6 as it is going for around $2.5k less than the 98. BUT the 98 comes with a 3month warranty and an LS1! ? what do you guys think would be a better buy? im steering towards the WS6. they can't possibly be That much slower than an "LS1, right?
Old 08-10-2005, 02:38 PM
Vendetta's Avatar
Get the LT1.
Old 08-10-2005, 02:39 PM
94stanger's Avatar
in your case, I would say go with the LS1 car. For similar mileage, somewhat similar price, and similar car....
Old 08-10-2005, 02:44 PM
Vendetta's Avatar
LT1 is abetter choice. Drop the 2.5k into it and you'll be good to go.
Old 08-10-2005, 03:03 PM
urbanhunter44's Avatar
Take the extra 2.5k and put a Lloyd Elliot setup in the car along with a few bolt ons. You'll rape the crap out of an LS1 with anything short of a cam. and you'll sound alot better doing it
Old 08-10-2005, 03:13 PM
Ibrahia's Avatar
how problematic is the optispark in the 97's? or is it the same as other LT1s?
Old 08-10-2005, 03:33 PM
matrik's Avatar
If I could do everything all over again. I would buy an LS1. I am so !@$#%### fed up with stupid lt1 problems. Leaking, breaking, and other crap. If you have the money, get the newer car, less problems and you get more power out of regular bolt ons. Don't get me wrong, I love how my car sounds, but I would GLADLY trade sound for a better car.
Old 08-10-2005, 10:01 PM
SlowBlueFormula's Avatar
When you start modding, things break...
If you don't want it to break, leave it stock.
Old 08-10-2005, 10:09 PM
_SHIFT's Avatar
...get the newer car? the one with less miles? ...the lt1? lol you said it yourself
all cars end up leaking breaking etc ...especially when you mod them
in my opinion get the lt1, if your worried bout the opti get a delteq for it , throw the extra money into full exhaust and gears and do whatever else you wna to it ....you'll love it ...trust me
Old 08-10-2005, 10:10 PM
infinitebird's Avatar
Definitely the LT1, like said above.
Put that $2.5k towards mods and you'll be way faster than if you had gotten the LS1.
Old 08-10-2005, 10:21 PM
With any older car you're going to have problems to fix. There aren't many miles on that car, so you'll be okay. I'd suspect your opti will have problems around 115k. That's where most people get problems. Mine lasted to 150k before it started acting up. The 97s have the later (better) vented opti design.
Like someone said above, if you don't want things to break, then leave the car stock.
You won't be disappointed with the LT1.
Old 08-10-2005, 11:35 PM
matrik's Avatar
My point was that from what i've experienced, thinks break way more on modded lt1's, than modded ls1's. My friends all have ls1's, and they have none of the oil leaks and stuff I have.
Old 08-10-2005, 11:56 PM
01WS6/tamu's Avatar
Shes not leaking oil shes marking her territory.
Old 08-10-2005, 11:57 PM
Vendetta's Avatar
That's because they burn the oil instead.
LT1s leak oil. LS1s burn oil. Ways of the world.
Old 08-11-2005, 02:14 AM
Moderator
BizZzatch350's Avatar
1997 has the vented, Optis arent that bad as half those guys in that post make them out to be. Its generaly user error that causes their death, people half *** it with shitty parts and get shitty results.
Old 08-11-2005, 02:34 AM
RoAdRaGe912's Avatar
another way to think about it is that the 97 is the last year of the lt1 and the 98 is the first year the ls1 was put in the fbody. the ls1 has it's own share of problems, which aren't to be looked over just because it's newer. i'm always skeptical of the first year run a motor has (even though it was in the C5 in 97). piston slap and the oil pump are obvioulsy an issue.
it's all up to you man, get what you want. if you want the ls1 and are willing to spend the extra money then do it, if not the lt1 won't do you wrong.
Old 08-11-2005, 06:10 AM
METALBEAST's Avatar
Yes, your extensive knowledge of having owned 1 whole LT1 makes you an expert in this field
Old 08-11-2005, 06:46 AM
Juiced2000SS's Avatar
I have to say get the LS1. Above there is an LT1 with headers, gears, converter, tuning, and a couple other things and it says best e.t. 13.2, that's probably more than $2500 in parts and most stock LS1's run that # JMO.
Old 08-11-2005, 12:23 PM
There are combos of parts that can get you WAY faster than 13.2 with a $2500 budget. If he payed to have someone install those parts then yeah that's around 2500, assuming they're good quality. But an LE H/C setup only costs about 1100 for the LE1, then add on 1400 in bolt ons and you're making 350-360 at the rear wheels, more than most full bolt on LS1s.
Old 08-11-2005, 12:31 PM
METALBEAST's Avatar
You can't compare what his time to what "some" ls1s run. Unless you have an actual LS1 that ran on the exact same day at the exact same track, its not a good point to make
Quick Reply: 97 LT-1 WS6 or 98 LS-1 Trans Am ?
