Lt4 heads
Old 10-06-2005, 03:23 PM
Quick96ss's Avatar
Default Lt4 heads
I have a hot cam kit but i dont have the lt4 heads or intake i am looking to buy the heads should i go with the gm lt4 heads or should i go with something else. I found the gm lt4 heads for 1,000 dollars should i get those heads and just port and polish them more or what should i do? Are the gm lt4 heads good for nitrous?
Thanks
Old 10-06-2005, 03:24 PM
Bawls's Avatar
Thanks
Keep in mind you cant just bolt the LT1 intake to the LT4 heads. So factor in the cost for a LT4 intake as well.
Old 10-06-2005, 03:26 PM
blind527's Avatar
You can port and polish the LT1 heads to flow better than the stock LT4 heads and they come with a whole set of new valvetrain. EPORTWORKS.COM
Old 10-06-2005, 04:04 PM
Gangly's Avatar
dont worry about either, use your stock heads and intake with the LT4 hot cam....if you decide to go with a bigger cam, then do heads, the LT4 hotcam is a small cam for a heads/cam application
Old 10-06-2005, 09:09 PM
Quick96ss's Avatar
so i should just port and polish my lt1 heads? any good places that do good work? What is the cost going to be for something like this? or should i get heads from elliots?
Old 10-06-2005, 09:58 PM
blind527's Avatar
EPORTWORKS.com if you want your LT1 heads ported or polished. You actually can get a better cam than the LT4 Hotcam.
Old 10-07-2005, 12:06 AM
Quick96ss's Avatar
i know but i already have it in and dont really want to take it out again unless i get a good deal on all the stuff to do it. if i could sell the hot cam i would change it in a second. i just put it in like 200 miles ago i got the whole cam kit the springs, rocker arms and cam. if i change it what should i change it to?
Old 10-07-2005, 12:44 AM
blind527's Avatar
Get the LE2 heads with the LE1 cam. It also depends on your goals and your mods now.
Old 10-07-2005, 07:59 AM
Quick96ss's Avatar
isnt the LE1 cam said to be similar to the hot cam? The cam is my only mod. i am doing nitrous this winter with heads and headers.
Quick Reply: Lt4 heads
